SAFC wiring
Old Aug 3, 2003 | 04:33 PM
turbospool's Avatar
Default SAFC wiring
I dont understand the wiring schematics on the apexi site so can someone tell me what color wire from the S-AFC to what color wire on the ecu harness i should hook up? Thanks. I dont want to run the hack, just regular standard hook up.
it goes the Big socket, small middle socket, and medium socket
94 LS stock ecu.
Old Aug 3, 2003 | 06:54 PM
turbospool's Avatar
Default Re: SAFC wiring (turbospool)
Old Aug 3, 2003 | 07:20 PM
Blown90hatcH's Avatar
Hmm...this is going to be a toughy to go off of the wire colors. Looking at their pics, you are following the wires into the ecu plugs. So basically comming from the engine bay and going into the ecu. Just look at the pics and find that wire.
Jason
Old Aug 3, 2003 | 07:22 PM
InTeGrA B18b1's Avatar
http://www.apexi.com has the manual for this
Old Aug 3, 2003 | 10:13 PM
turbospool's Avatar
Default Re: SAFC wiring (InTeGrA B18b1)
can someone tell me what color wires i need to use from the safc? and what each color represents? thanks
Old Aug 3, 2003 | 10:28 PM
guido-kp's Avatar
ok my safc is the blue digital one with buttons. its got several wires on it.
green is tach
gray is throttle position
red is B+
brown is ecu gnd (closer to ecu)
black is ecu gnd (further from ecu)
yellow is MAP out
white is MAP in.
use these at your risk, as its from memory.
Old Aug 4, 2003 | 12:19 AM
turbospool's Avatar
Default Re: (guido-kp)
thanks,does anyboyd know what color the MAP in and MAP out wires are on the ecu harness?
Modified by turbospool at 12:36 PM 8/4/2003
Old Aug 4, 2003 | 11:39 AM
turbospool's Avatar
Default Re: (turbospool)
bump
Old Aug 4, 2003 | 09:27 PM
TURBO B's Avatar
bump for the same question
HarosGSRek
May 21, 2009 12:36 PM
siis2fast
Jul 3, 2004 01:26 PM
vet_girl
Dec 23, 2003 01:14 PM
turbospool
Aug 4, 2003 11:38 AM
