Sad but true
Old Jan 4, 2009 | 12:02 PM
yakuza's Avatar
Default Sad but true
Yep, after long wait and too much money the Sol didn't even make 600 miles before it went Kabooom sideways on the motorway ..
I have managed to save the most expensive parts of the car including the engine, ECU & whole 3" down pipe and exhaust. These all cost more than the car it self. Think next I will get civic hatch EG6 and drop the engine into it. I someone how belive I will get better traction also on the civic rather than the Sol.
1 drive shaft completely broken, another got signs of wear around the edges which makes it useless. The Garret 57 trim trubo has only 500 miles on it but the shafts seems to have seized from the impact and don't spin, might be repairable but I will consider something smaller this time. Something that can spool within the 3K RPM range instead of late 4.5K RPM. Also might switch to ram horn manifold this time even though all this mean re-working the down piple and more cut and weld to fit the new setup.
Putting the engine and gear box into my DD D-series civic, the damn thing so heavy the car went all way down.
Old Jan 4, 2009 | 12:19 PM
srmofo's Avatar
Default Re: Sad but true
ouch, what happened?
Old Jan 4, 2009 | 01:19 PM
arc_55's Avatar
sad to see but atleast your looking forward in a postive way. What exactly happened?
Old Jan 4, 2009 | 01:40 PM
boostedcivicsir's Avatar
Mr. Badwrench
stinks what happened, glad you are ok. not tech.
Mlo93
Dec 26, 2015 07:06 AM
jd2dub07
17
Aug 15, 2007 08:19 PM
_93delsol_
Jul 19, 2005 12:57 PM
_93delsol_
14
Jul 16, 2005 11:42 AM
importstart
Jan 31, 2002 10:19 PM
