S300 Nitrous wiring
Old May 14, 2009 | 03:00 AM
1sikhatch's Avatar
Default S300 Nitrous wiring
ok am trying to understand this goin from the hondata website, i have a 96 civic on the ecu do i hook up the wire to b8 or b5 and a15 or a20? and should i have a ground going to the switch right?
Old May 14, 2009 | 03:07 AM
wolve's Avatar
Default Re: S300 Nitrous wiring
let the ecu read the ground trough the switch!
wich input or output you'll use, you can probably select in the s300 software.
in ectune i can choose from a dozen inputs or outputs, just browse trough the program
Old May 14, 2009 | 07:28 AM
Turbo-LS's Avatar
Correct just choose which ones you want to use in the software and wire accordingly
hardcore97
Engine Management and Tuning
Aug 23, 2013 01:43 AM
a1320honda
Oct 13, 2012 08:40 AM
champwhiteEG6
Oct 17, 2008 04:48 PM
gearhead16
Sep 3, 2008 11:58 AM
