s300 or neptune
Old Aug 18, 2007 | 10:15 PM
sluggo's Avatar
Default s300 or neptune
Was wondering which is better as far for my setup shooting for 650whp setup 84mm ls/vtec gt40r, type r head with valve train pro1 cams full-race divided mani and 4inch dp just trying to decide by the two i have tuners in the area that will tun either just trying to see which is more reliable out of the 2 or least amount of problems will run stock dizzy or time being until Tony 1 has t1 trigger kit for either one
Old Aug 18, 2007 | 10:21 PM
SD_Lurker's Avatar
HT White Ops
Default Re: s300 or neptune (sluggo)
Its really personal preference. Ask your tuner what he likes to tune with and see which one he prefers. Both are very good and you can't go wrong with either. I would say ask your tuner which one he likes and go with it.
Old Aug 18, 2007 | 10:24 PM
sluggo's Avatar
both the tuners i have talked to said the could do either one no problem so now i am just trying to get sum input as far as pros and cons of each
Old Aug 19, 2007 | 05:59 AM
93turbo16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sluggo &raquo;</TD></TR><TR><TD CLASS="quote">both the tuners i have talked to said the could do either one no problem so now i am just trying to get sum input as far as pros and cons of each</TD></TR></TABLE>
If you are only taking the car to the tuner and not tuning at all yourself. I would say go with Neptune. It will be a little cheaper and you will get the same results.
Old Aug 19, 2007 | 06:34 AM
MeanGreenMachine's Avatar
Default Re: s300 or neptune (93turbo16)
there have been numerous threads concering s300 vs neptune, its been discussed multiple times. i my self am going with neptune rtp. i have had close friends who've had s300 and have had good results. i myself have never useed neptune nor have any of my friends, so i thought idgive it a try...
but its like sd_lurker said, you cant go wrong with either of em....who is the tuner thats going to tune your vehicle?
Old Aug 19, 2007 | 07:08 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: s300 or neptune (MeanGreenMachine)
honda ecu's cant use the t1 trigger. asked him about that. the ecu is not setup for a hall sensor.
made 710 on hondata s300.
stock dizzy msd 6al and a blaster ss coil
are you comparing s300 to regular neptune?
no comparison in terms of convenience. neptune = chips and a burner. s300 is flash. now if you are talking about rtp thats a little different.
i ran s200b last year and it was fine, this year i didnt want chips and wanted datalog. i think it is a great buy.
Old Aug 19, 2007 | 09:40 AM
mtber's Avatar
Default Re: s300 or neptune (boostedcivicsir)
s300 has boost by gear
neptune has staged boost controller options
Those are the major differences.
Old Aug 19, 2007 | 10:23 AM
dbiker207's Avatar
Default Re: s300 or neptune (mtber)
newptune has a nice system for launch control. hold the engine at a steady rpm for 2 seconds and then mat it, the launch controll will now be where you held it steady. hondata can only set a launch control with a laptop and the driver cant change the rpm easily. this sucks if you run street tires and slicks.
Old Aug 19, 2007 | 01:01 PM
Mr. Badwrench
Default Re: s300 or neptune (dbiker207)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dbiker207 &raquo;</TD></TR><TR><TD CLASS="quote">newptune has a nice system for launch control. hold the engine at a steady rpm for 2 seconds and then mat it, the launch controll will now be where you held it steady. hondata can only set a launch control with a laptop and the driver cant change the rpm easily. this sucks if you run street tires and slicks.</TD></TR></TABLE>
well that depends on s200 or s300
the s200 you can change it with the switch. there is a vid on how to do it:
http://hondata.com/s200media.html
the s300 you need a lap top yes, but again NO CHIPS! w00t!
Old Aug 19, 2007 | 01:10 PM
dbiker207's Avatar
couldnt you use a ostrich from moates.com instead of chips with neptune?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">
Old Aug 19, 2007 | 01:13 PM
gokhan's Avatar
i think with a neptune rtp you dont need to burn a chip, just tune it like hondata s300.
Old Aug 19, 2007 | 04:23 PM
sluggo's Avatar
i was talking about neptune rtp
Old Aug 19, 2007 | 04:49 PM
tony413's Avatar
they both work just go look at the features of both and see which ones you want the most. s
Old Aug 19, 2007 | 06:44 PM
xenocron's Avatar
Default Re: (tony413)
The only differences between S300 & Neptune RTP:
S300 offers PWM boost control, on board logging and a heftier price tag.
Both can acheive the same numbers easily...if you NEED the features above, go S300. If you dont...
BTW...there is NO chip burning with either setup.
HTH
Old Aug 19, 2007 | 07:50 PM
sluggo's Avatar
Default Re: (xenocron)
thnx for all the advice apprecaited
AussieGSR
Mar 29, 2008 10:21 PM
ben98gs
Honda Civic (2001 - 2005)
21
Jul 9, 2007 08:30 AM
pudgey26
Jul 29, 2006 06:10 PM
Quickgti1.8t
Apr 7, 2006 11:52 PM
crxsimike
Apr 5, 2006 11:34 AM
