S-AFC hack on pre-obd
Old Oct 17, 2002 | 08:02 PM
MADEINIRAQ's Avatar
Default S-AFC hack on pre-obd
first of all.. is there anybody running a turbo b16 that didn't convert to OBD-1. if so. where are your 02 sensors located
second. Is anybody running the S-AFC hack with a pre-obd ecu.
Old Oct 17, 2002 | 08:05 PM
zexdrex's Avatar
Default Re: S-AFC hack on pre-obd (madeiniraq)
im running the hack on my 90 ls ecu for a turbo zc
works fine
Old Oct 17, 2002 | 08:17 PM
MADEINIRAQ's Avatar
Default Re: S-AFC hack on pre-obd (zexdrex)
i'm talkin about the pr3 ecu with 2 oxygen sensors
Old Oct 17, 2002 | 08:40 PM
filetofit
Guest
Posts: n/a
I've got the PR3 ECU but I disabled closed loop.
Old Oct 17, 2002 | 08:44 PM
sutrusu's Avatar
Default Re: S-AFC hack on pre-obd (filetofit)
oh no... are you going to go turbo?
Old Oct 17, 2002 | 08:51 PM
MADEINIRAQ's Avatar
Default Re: S-AFC hack on pre-obd (sutrusu)
of course..... you can't go wrong with turbo.
Old Oct 17, 2002 | 09:06 PM
filetofit
Guest
Posts: n/a
I disabled closed loop. That means I don't need o2 sensors, better for turbo, not so good for mileage.
Old Oct 17, 2002 | 09:08 PM
MADEINIRAQ's Avatar
how do you disable it...
so you pretty much turned your fuel injection setup into an electric carburetor
Old Oct 17, 2002 | 09:15 PM
filetofit
Guest
Posts: n/a
An electric carburetor, I never heard it put quite that way but I suppose.
It's disabled with a custom chip in the ECU.
[Modified by filetofit, 6:16 AM 10/18/2002]
Old Oct 17, 2002 | 09:17 PM
MADEINIRAQ's Avatar
you could probably call it a faucet.. you press the pedal and it gives fuel.
Old Oct 17, 2002 | 09:18 PM
filetofit
Guest
Posts: n/a
Pretty much.
Old Oct 18, 2002 | 08:22 PM
MADEINIRAQ's Avatar
bump
Old Oct 19, 2002 | 02:50 PM
joshwhe's Avatar
bump for a nice ride yo.
F.T.A
Aug 25, 2010 08:12 AM
F.T.A
Aug 25, 2010 08:11 AM
qqqq
Apr 30, 2003 04:11 AM
