S-AFC 2 Bar settings?
Old May 3, 2004 | 06:27 PM
Tushner's Avatar
Default S-AFC 2 Bar settings?
Anyone know what to set the IN/OUT settings on a S-AFC to accept a 2bar map sensor?
Note: car is pre-OBD0. Timing is independent of ECU operation. Fueling only. PG6 ECU.
Thanks for any help.
Old May 4, 2004 | 09:41 AM
Tushner's Avatar
bumparoo
Old May 4, 2004 | 01:09 PM
AROD's Avatar
bump for the 3 bar setting too
Old May 4, 2004 | 02:14 PM
Tushner's Avatar
Default Re: (1.83Tc)
14 in and 14 out for the 3 bar, I believe.
Old May 4, 2004 | 04:18 PM
notoriousB's Avatar
wouldn't it be 6 out to fool the honda ecu into thinkin the stock map sensor is in use?
Old May 4, 2004 | 09:03 PM
Tushner's Avatar
Default Re: (notoriousB)
6 out if you want to put everything in negatives. 14 out if you want the thing calibrated to 0.
https://honda-tech.com/zerothread?id=137901
Old May 11, 2004 | 01:36 PM
Tushner's Avatar
Biddunkidunk
I mean bump.
Old May 15, 2004 | 12:32 PM
Tushner's Avatar
Default Re: (redteg_87)
UPDATE:
06 in / 06 out might work.
I'll try it out.
EX-T
May 26, 2006 05:06 AM
teggreen4
May 22, 2005 11:55 AM
89civic1.8T
Jul 12, 2002 11:22 AM
