RX7 Turbo Resistor Pack
I have a resistor pack from an 88 rx7 turbo II. Will it work to use 450s? If so how do i wire it up. There are only 2 wires coming out of the resistor pack. Thanks
The resistance needs to be ~6 ohms between the inlet wire and each outlet wire. Since you only have 2 though, I wouldn't use it. Get a Honda one from the junkyard. They are like 10 bucks there and all you've gotta do is take it out and clean it.
Sonny
Sonny
jfruauff
May 5, 2007 07:13 AM
