Running super rich...?
Old May 7, 2007 | 07:37 PM
CO_CReX's Avatar
Default Running super rich...?
Ok, I finally got my motor and turbo back in the new car and started it up. The car is running SUPER rich in the lower RPM's 4K and less and is really killing me. Once the car hits VTEC it seems to burn off all the extra fuel because it freakin flies. My question is why is it running rich? I have no CEL's and everything seems to be running fine. It sounds like there may be a miss fire in one of the cylinders too because it sounds like I have a super aggressive cam.
NOTE: I hooked up my Walbro 255 fuel pump to a switch and it is getting 14amps when the car is running due to alternator instead of the normal 12 after the fusebox. Could this be a good reason why its running rich?
-I also have an AEM FPR which should be keeping the right fuel pressure even though the walbro is getting more amps... I would think at least. Let me know if Im wrong about this.
Any help would be great! Thanks guys!!
Old May 7, 2007 | 08:41 PM
1995Civic's Avatar
Default Re: Running super rich...? (CO_CReX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CO_CReX &raquo;</TD></TR><TR><TD CLASS="quote">Ok, I finally got my motor and turbo back in the new car and started it up. The car is running SUPER rich in the lower RPM's 4K and less and is really killing me. Once the car hits VTEC it seems to burn off all the extra fuel because it freakin flies. My question is why is it running rich? I have no CEL's and everything seems to be running fine.</TD></TR></TABLE>
Usually when you first put a turbo on, the car will run rich. Running rich will usually never pop a CEL.
What injectors are you running, and what turbo are you running? Is it new?
Also, you also have to remember that you are not tuned. The air/fuel is probably way off. Is the smoke black for sure?
What motor is this on?
Old May 7, 2007 | 09:10 PM
iBrandon's Avatar
Default Re: Running super rich...? (1995Civic)
Get it tuned, get it tuned, get it tuned! tuned! tuned!
Old May 8, 2007 | 06:20 AM
sp00led's Avatar
Default Re: Running super rich...? (iBrandon)
I wouldn't run it less then 10 afr for to long. It will drive like **** and coat the back of your car black. Also the extra fuel will wash some oil away and start to put some wear on your rings.
Old May 8, 2007 | 01:45 PM
CO_CReX's Avatar
Ok I should of specified this in the first post. I AM TUNED. Im Neptuned for 18psi. I didn't do anything to this motor when it was pulled. I yanked it and put in on an engine stand. and now its in the new car. Only thing I really changed was installed a GE Vacuum block and installed a fuel pump switch......
Any help?
Old May 8, 2007 | 03:18 PM
CO_CReX's Avatar
I put new plugs in the car and they are almost instantly covered in gas. Why the hell is this thing running so freakin rich?!
Help please!!?
Old May 8, 2007 | 03:38 PM
sp00led's Avatar
Default Re: (CO_CReX)
That is a good question, bump for any ideas.
Old May 8, 2007 | 04:22 PM
Topdawgg's Avatar
so you didnt change a thing at all with the engine or tune?
just the vacuum manifold ?
its still running fine but just rich in low rpms?
hows the vacuum to the regulator? and map sensor?
is it idling fine?
Old May 8, 2007 | 06:03 PM
CO_CReX's Avatar
nm, I figured it out. IACV was freakin out.
DawgC2
Mar 10, 2012 12:11 PM
H22CL
Jun 20, 2004 11:11 AM
jeremy.
Sep 27, 2003 02:12 PM
speedaccordinly24
Apr 25, 2003 04:15 AM
