rs machine pistons
I have a b18b I want to boost I already have a set of eagle rods and arp stud 57 trim turbonetics. Shooting for 300whp do you guys think thes pistons would handle them ...also heard of b series vitara pistons but I can't find them
http://rsmachines.net/pistons.html
RS is a cast piston. it will work at 300whp and if you aren't going to go higher, have a good tune and desire a long life it's a thought. the drawback to RS is the same as using stock pistons. they won't survive detonation and are easier to injure. the draw to cast is being able to use a .0010-.0020 piston to wall clearance which is considerably tighter than the .0025 absolute minimum you'll see with even the lowest expansion forged piston. tighter clearances mean no cold rattle and a longer ring and bore life
If your going to put all those goodies into that block, put slugs in and be done with it. SRP's work great and are a low expansion forged piston. Ive been running mine for 30k miles, car runs great 400whp all day long
Thats what i thoughthave but What are these
https://honda-tech.com/forums/drag-racing-36/putting-bseries-vitaras-test-2627756/
Supertech pistons are not Mahle pistons, nowhere close in fact. Supertech's pistons are made buy IASA, a forged piston manufaturer located in Argentina. The Supertech piston actually uses a Mahle 124 Alloy which is similar to the standard 4032 used by most piston manufacturers. Mahle 124 does have a few slight advantages over 4032, but I'm not really going to get into any of that. Mahle makes an awesome piston, when they want to. Their production stuff is decent, just not up to par with some of the higher end Mahle stuff I've gotten my hands on over the years. Supertech's pistons are nice, not the best out there, but not the worst either. I like them a lot for street NA use, actually. Its a good bang for buck NA piston.
http://forums.evolutionm.net/evo-eng...ns-before.html
which is the iasa made piston with a mahle forging
you 100% on that? i've read everything from re packed powerpak pistons to iasa pistons with mahle forgings. the common net rumor is the same one over at evo world in this thread about mid way down?
You have to ask yourself a really simple question as well about this. Why would Willie buy a piston from Mahle and re-sell it at a net loss? It doesn't make any sense at all. Not to mention the forgings themselves that are the basis for Supertech pistons are different from the forgings that end up the Mahle Powerpak pistons.
Supertech pistons are Supertech pistons. They are Supertech forgings produced and machined for Supertech by IASA to the specifications provided by Supertech.
Thats it. Hopefully that clears up the mis-information out there.
Another example. RR58 is another popular alloy used for forged pistons as well. It's very similar to 2618, with some advanteges. It's more expensive than 2618. The RR stands for, "Rolls Royce." But any forgings made in RR58 by Accralite, Perfect Bore, etc belong to the companies who produce them. Not Rolls Royce.
ycp makes vitara pistons that most people use, i think they might have a b series version as well.
http://www.ebay.com/itm/YCP-Honda-Ci...ht_2977wt_1185
you do realize that RS pistons are cast right?
if supertech is using mahle 124 alloy that would be a nice low cost choice. the one really nice benefit of 124 that i came across reading up is that it's less brittle than 4032 while being still low expansion.
