Which route for an FI Integra Type R?
Old Jul 21, 2001 | 03:51 PM
JSpecwest's Avatar
New User
Default Which route for an FI Integra Type R?
I have a 98 Type R with 30,000 miles on it. Im struggling between purchasing a Jackson Racing Supercharger or a Drag Gen. III Turbo kit. Everyone says a supercharger is safer, but why is this so? The main issue is reliability. I want to be able to drive my car for another 70,000 miles or so SAFELY. If a turbo is tuned right (injectors, haltech standalone ignition and fuel) is it possible to have a reliable car if I keep the boost under 7 psi? I know the type R compression is not good for turbo but there are quite a few type r's running 7 lbs. safely. But my question is, how long? The next issue is power. Obviously a turbo is going to make more power since the supercharger takes power to make power. How much boost is possible with a supercharger on a stock type R ecu and bottom end? Will it get me into the low 13's or even high 12's (w/ slicks)? Current mods are as follows: Apex N1 w/ 2 1/2 all the way from the header with no cat, JDM Type R header, Skunk2 cam gears, ACT six puck racing clutch. Sorry for the long post but this is a big decision. Thanks for the help...
Old Jul 21, 2001 | 04:50 PM
TurboITR's Avatar
Default Re: Which route for an FI Integra Type R? (JSpecwest)
i have had both - SC is fun but left me wanting more power. Turbo cars are just as safe as SC cars - it all comes down to tuning, if its tuned right you can get another 70,000 out of your car. The compression issue is just a myth - like i said if the turbo is tuned at .5bar it will work just fine with the R compression. If you wanna save money (since you already have a header, etc.) and are afraid of screwing with your emissions go with the SC - if you want sheer power go with the turbo - either way you will be happy - the real question is for how long...
[Modified by TurboITR, 5:57 PM 7/22/2001]
Old Jul 21, 2001 | 09:01 PM
Hondata's Avatar
Here is the result of some tuning we did on a 2000 SC Type R at a low 4.5 Lb boost on Thursday.
http://Hondata.com/dyno00sctyper.html
It has a very flat torque curve, which makes it very easy to drive.
Old Jul 22, 2001 | 12:48 AM
Mr Integra's Avatar
New User
Default Re: Which route for an FI Integra Type R? (Hondata)
i just visted the site.. so with 6 psi supercharger, all i would need is 440 cc injectors + hondata stage 2 with boost? i don't even have to upgrade my fuel pump..?
Old Jul 22, 2001 | 12:32 PM
JSpecwest's Avatar
New User
Default Re: Which route for an FI Integra Type R? (Mr Integra)
Does anyone have a dyno sheet on a turbo ITR? Thanks Hondata for the info. How much boost is possible with a JR supercharger?
[Modified by JSpecwest, 9:34 PM 7/22/2001]
Old Jul 22, 2001 | 12:59 PM
austrian type-R's Avatar
On a stock B18C5 I would boost max. 8psi. The charger itself can boost 10-12psi. Anything higher and the air will get too hot to see any power gains. You can port and polish the charger to produce less heat under the same boost-levels. There is always the possibility to install a water-injection too cool down the charged air. Anything higher than 16psi and the rotors of the JRSC get supersonic and can cause heavy damage to the blower and engine.
Old Jul 22, 2001 | 01:57 PM
TurboITR's Avatar
Default Re: Which route for an FI Integra Type R? (austrian ITR)
I ran .5bar and hit 226whp@9200 with my SC. At .5bar on a stock R with turbo I would guess around 275whp (with tuning)
BTW - go with hondata
[Modified by TurboITR, 5:58 PM 7/22/2001]
young geezer
Aug 23, 2008 08:56 PM
jdm2teg
Sep 27, 2005 12:11 PM
digital sol
Sep 24, 2005 04:51 PM
scarface
Sep 30, 2002 06:45 PM
JSpecwest
Jul 21, 2001 10:51 PM
