Rod and Piston combo??
Old Feb 28, 2002 | 04:05 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Rod and Piston combo??
8.8 JE PISTON, EAGLE ROD. What do you think?
art
falcongsr's Avatar
What is this crap?
Default Re: Rod and Piston combo?? (Arturbo)
why man? why???
Old Feb 28, 2002 | 04:06 PM
dustin's Avatar
ne1 got xs turbo intercool for sell need sale quik
Old Feb 28, 2002 | 04:09 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Rod and Piston combo?? (dustin)
I was thinking of this combo because I went over to The Racer's edge and ordered 3 spoon motors and motec system exhaust. So I figure I could put in 8.8JE PISTON, EAGLE ROD with my 3 spoon motors.
Then Im gonna run 12:1FMU with 19psi and walbro pump. What about a supra pump will that work?
And one more thing, is pressure the same as flow?
art
Old Feb 28, 2002 | 04:10 PM
DLB1994's Avatar
lololololol
Old Feb 28, 2002 | 04:13 PM
dustin's Avatar
I am going to turbocharge my integra GSR soon. The only thing is I don't have much money at all (I work at McDonalds) so I don't have money for stuff like a boost gauge and stuff.
My car has to be 100% reliable because it is my daily drive to and from work. Since the turbo is always spinning and making boost I don't want to be boosting on the freeway? Should I buy a boost controller and turn the boost to zero?
I can't afford to fix my motor if it breaks...so I need something reliable. I heard that the 12:1 FMU and Walbro intank work great together!
Also, will DC headers work well with this setup? How about an AEM intake? i heard cold air is the way to go.
Old Feb 28, 2002 | 04:22 PM
robbin's Avatar
You won't be boosting unless you open the throttle really wide. If you're just cruising you may be boosting like 1 psi but that probably wont blow your engine.
Old Feb 28, 2002 | 04:23 PM
immortal's Avatar
Banned
who had that groupbuy on Motec 1 intercooler oil?
immortal's Avatar
Banned
Default Re: Rod and Piston combo?? (robbin)
you did not just seriously reply to dustins post.
Old Feb 28, 2002 | 04:24 PM
G's Avatar
G
Here we go again.......
Can you hear me now???
Good.
Good.
dustin's Avatar
Ok thanks. See here on H-T people help out instead of playa hate!
Old Feb 28, 2002 | 04:30 PM
Arturbo's Avatar
Better than steak
25 Year Member
ok so let me get this..so I wont get boost untill throttle is really wide? So if I bore out my throttle body and make it wider, will I boost all the time? What is WOT? so with 8.8JE PISTON EAGLE ROD and 1psi I wont blow my engine? Can a get a ***** to blow my engine?
Old Feb 28, 2002 | 04:32 PM
Dee's Avatar
Dee
don't forget to get a set of 295/20-25 mashimoto R spec tires for the front!
Old Feb 28, 2002 | 04:46 PM
downpipe's Avatar
brilliantly done.
Old Feb 28, 2002 | 04:53 PM
downpipe's Avatar
art
8.8 JE PISTON, EAGLE ROD this works is greatly good. get midrange nice spool but blue box surprise me!!! BOO!!! car goes zoom fairly quick not runs lean!
long live 8.8 JE PISTON, EAGLE ROD 4EVA
Old Feb 28, 2002 | 04:56 PM
Xerxes's Avatar
New User
****** newbie
you need 3 8.8 JE PISTONs and 3 EAGLE RODs, one for each spoon motor!
yes if you ***** out your engine and put in long sleeves you will be a-o-kay. I don't know why honad uses short sleeves.
then u can bost 1-2bars on stock intornols and be smokin mustags all dya
-Xerxes
Old Feb 28, 2002 | 04:59 PM
G's Avatar
G
Don't we all just love the foced induction board?
Anyone heard of BC Bud?
Maybe the banner up top has a narcotic effect.
Good.....
Old Feb 28, 2002 | 06:33 PM
HXMan's Avatar
Since all yous know your ****...answer me this.
How well will 8.8 JE PISTON, EAGLE ROD work with my JRSC? I want absolute reliability. I fell with me pushing 356.98wbhp every day that some internal modifications are necessary. I hit 405 once, but that was after I messed up adjusting the EBC..........
Old Feb 28, 2002 | 06:38 PM
Flamenco-T's Avatar
Default Re: Rod and Piston combo?? (HXMan)
what's the best turbo kit....
can I start a poll ??
rev-hard, drag or F-max ?
Old Feb 28, 2002 | 06:40 PM
SEFIxCivic's Avatar
i hear beer in your gas tank will up the octane to 118.
Old Feb 28, 2002 | 06:44 PM
Flamenco-T's Avatar
Default Re: Rod and Piston combo?? (SEFI8LOxCivic)
depends, lite beer can only get you 105 octane..
guiness, hmmm another story...118 is achieveable..
Old Feb 28, 2002 | 07:29 PM
1's Avatar
Default Re: Rod and Piston combo?? (Flamenco-T)
Is it o.k. to downshift in a torocharged Honda???
Old Feb 28, 2002 | 07:31 PM
Sh4rky's Avatar
No! Are you silly? DC headers are NOT a good choice with turbo setups. The aluminum, that they're made of, can't withstand the amount of intercooled boost running through them, and they tend to crack because of the extremely cold, compressed air that the intercooler pushes through them. I suggest going with Greddy copper headers or Mugen zinc ones. They withstand the cold temperatures much better.
P.S. Make sure you go with a 4-1-1 header setup, that way all 4 fuel injectors will be activated when the VTEC kicks in, giving you additional boost, and prevent your engine from running too lean!
Hope this helped!
Sh4rky
[Modified by Sh4rky, 10:40 PM 2/28/2002]
Old Mar 1, 2002 | 12:46 AM
Giuseppe's Avatar
art
u crazy...!!
11:1 piston https://honda-tech.com/zerothread?id=133343
Old Mar 1, 2002 | 12:48 AM
downpipe's Avatar
8.8 JE PISTON, EAGLE ROD is my wet dream. i've seen this setup alone, with NO MOTOR run low 10's in the 1/4. with the JRSC you will be in the low 5's, AND get daily drivability, great gas milage and last 4EVA...
8.8 JE PISTON, EAGLE ROD 4EVA!!!
