rod choices for d15b?
well the d15b rodlenght is the same as the z6
I was under the impression you could use z6 rods in the d15b
so then why not just pick any aftermarket rod for the z6, theres gotta be plenty.
i recommend eagle after seeing brewerhatches post..
a completely incinerated engine.. but the rod was unscathed, haha.
the rod lenghts are different between D15 and D16's
u cant mix match them
also the D16's bearings are 55mm when the D15's are 45mm
i say call ea of the famous manufactures cust serv and just spend 2 min to ask them if they carry it or not
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC »</TD></TR><TR><TD CLASS="quote">the rod lenghts are different between D15 and D16's
i say call ea of the famous manufactures cust serv and just spend 2 min to ask them if they carry it or not</TD></TR></TABLE>
JDM D15B is different. It uses the larger 1.6 rods with the 45mm big ends.
Modified by Jim Truett at 3:15 PM 12/10/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett »</TD></TR><TR><TD CLASS="quote">JDM D15B is different. It uses the larger 1.6 rods with the 55mm big ends.</TD></TR></TABLE>
exactly.
exactly.
JDM D15B is different. It uses the larger 1.6 rods with the 55mm big ends.</TD></TR></TABLE>That is incorrect. The d15b has the same rod length - 137mm as a d16z6 but has the same small bearing size of a d15 - 45mm. So you have to get custom one's made. Call pauter or crower they have the specs already on file.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slywfbpsi »</TD></TR><TR><TD CLASS="quote">That is incorrect. The d15b has the same rod length - 137mm as a d16z6 but has the same small bearing size of a d15 - 45mm. So you have to get custom one's made. Call pauter or crower they have the specs already on file.</TD></TR></TABLE>
Not true. Trust me, I have built them. I simply hit 5 instead of 4 in my previous post.
on me for not proofreading. The rods on the 1.6 have 45mm big ends as well. the mains are 55mm on the 1.6 I believe, with 45mm mains on the 1.5s, the D15B included.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves »</TD></TR><TR><TD CLASS="quote">I thought the D15B had the same rods as the Z6 motors, or maybe its the same pistons then..</TD></TR></TABLE>
Pistons are different. Z6 uses P28 pistons, where the D15B uses a shallower dish P08 piston. Rod big ends are the same size, but I didn't measure length when my engine was disassembled.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC »</TD></TR><TR><TD CLASS="quote">but since everyone is going to call BS, u going to have to ask Mista Bone, Earl, or call some manufacturer or something
Why, when I have three motors and 5 transmissions in various states of disassembly in my garage. I have micrometers, and I know how to use them. Damn man, seriously. The B18C only has 45mm rod journals and 55mm mains. If you have a D with 55mm rod journals, I will buy it from you right now. Oh wait, they wouldn't swing through the crankcase unless the stroke was like 65mm.
That would net 1148cc with a 75mm bore.
Ok SO... d16z6 rods are the same as JDM d15b SOHC VTEC rods right? lol
I'm getting a set of LS rods machined to fit my new d15b soon. So then the changes that need to be made to LS rods to fit a d16 are the same changes that need to be made for the LS rods to fit the JDM d15b.
These are the specs I found on here:
D16 Bottom end width is .892" and the pin diameter is 19mm (.784")
B18 Bottom end width is .935" and the pin diameter is 21mm (.826")
So .0125" needs to be milled off each side of the bottom and the top end needs to be re-bushed to 19mm.
Its probably a good idea to take the JDM d15b rods with me anyways to the machine shop eh?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-RO »</TD></TR><TR><TD CLASS="quote">Ok SO... d16z6 rods are the same as JDM d15b SOHC VTEC rods right? lol
let me know how this works out. I wanna do pistons and rods in my boosted D15b soon..
</TD></TR></TABLE>let me know how this works out. I wanna do pistons and rods in my boosted D15b soon..
I sure will. I'm looking at a Jan timeframe. Hopefully it wont be too long. The cars been sitting for months now.
P.S. I saw youre in Central FL. also. If everything works out well i'll let you know where I had everything done.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-RO »</TD></TR><TR><TD CLASS="quote">I sure will. I'm looking at a Jan timeframe. Hopefully it wont be too long. The cars been sitting for months now.
P.S. I saw youre in Central FL. also. If everything works out well i'll let you know where I had everything done.</TD></TR></TABLE>
coo coo.. But i plan on installing the rods and pistons myself..
maybe a block guard too.
BTW I used to live in Deltona too. Graduated from Deltona High 2 years ago.
maybe a block guard too.BTW I used to live in Deltona too. Graduated from Deltona High 2 years ago.
yeah just do that i say.
</TD></TR></TABLE>yeah just do that i say.
