RIP GT3076R :(
I've got about 20k miles on my setup. I finally got all the little quirks worked out so I've actually been truly daily driving it for the last 2 months (4k miles in 8 weeks).
This past weekend I was replacing the air filter and noticed it had about 2-3mm of what I assume is shaft play when I pushed/pulled on the wheel. Felt great all week and this morning. I went to pass someone on the way home and heard a faint noise and noticed it wouldn't spool. Not even 0-1psi. The wheel won't spin by hand :( Guess this is my excuse to get the GTX3076R! Any idea the average life span of the GT ball bearing turbos? |
Re: RIP GT3076R :(
You confirm the wheels are no good? Maybe the housing bolts came loose? Just trying to shed a glimmer of hope hahahah
Re: RIP GT3076R :(
Im going to pull it off this weekend. It's a full race ac bottom mount so it's pita to remove. All I did was try and move the wheel by hand. It would barely spin a partial rotation counterclockwise.
Re: RIP GT3076R :(
Maybe it's not damaged see if the bolts for the housings came loose
Re: RIP GT3076R :(
You really wont know what happened until you remove the turbo man....you couldve easily sucked up a vacuum hose and find it in your intercooler core like I did lol....If you cant spin the compressor wheel freely thats not a good sign....take a few snapshots and post them in this thread... might help to find out what exactly happened. Otherwise if it remains a mystery it could likely happen again on the new turbo which you def dont want..
Re: RIP GT3076R :(
Ehhh if the bolts came loose the only way they'd keep the wheel from spinning is by contacting the blades. That's not any better. :/
Re: RIP GT3076R :(
The compressor side housing bolts/clamp aren't loose. From what I can see of the compressor wheel it doesn't look chipped or damaged. Of course I may not not be able to see any damaged area because of the housing from what I read in other threads.
https://honda-tech.com/forums/forced-induction-16/garrett-chra-exchange-program-gt35r-2958967/ This thread gives me hope. I'd be happy to pay $450 for an exchanged CHRA. It's times like these I wish that top mount manifolds were out back in 07' when I built this car. Not much room to fit your hands let alone turn a wrench... I hope to have it out and post pics over the weekend. |
Re: RIP GT3076R :(
http://home.mchsi.com/%7Ematt5183/turbo.JPG
http://home.mchsi.com/%7Ematt5183/turbo2.JPG http://home.mchsi.com/%7Ematt5183/turbo3.JPG First thing I noticed was that the oil return looked a little to dry. However once i took the oil feed off it looked like it wasn't plugged or a dry feed line like I suspected. Then I took the oil return fitting off the CHRA and noticed it plugged up with a plastic looking ball bearing holder and a few bb's fell out. |
Re: RIP GT3076R :(
Originally Posted by sp00led
(Post 46888347)
http://home.mchsi.com/%7Ematt5183/turbo2.JPG http://home.mchsi.com/%7Ematt5183/turbo3.JPG First thing I noticed was that the oil return looked a little to dry. However once i took the oil feed off it looked like it wasn't plugged or a dry feed line like I suspected. Then I took the oil return fitting off the CHRA and noticed it plugged up with a plastic looking ball bearing holder and a few bb's fell out. also, may be a silly ? but were you using the water lines? |
Re: RIP GT3076R :(
ouch!
sorry buddy |
Re: RIP GT3076R :(
Sorry to hear about that Lee. Hit me up if you need some assistance
Re: RIP GT3076R :(
Sucks to hear man....I had the oil line get clogged on my 3076r, ran dry started spitting out bearings.....I know your pain lol.
Re: RIP GT3076R :(
You should be able to get a discount through the exchange program, even with a bad cartridge, as long as the wheels and housing are good. You may want to try that approach. We've done that before and it was less than a newer unit or even a replacement Precision.
Re: RIP GT3076R :(
Originally Posted by prsxr88
(Post 46888394)
woah, looks like it all heated up. you said the feed was wet?
also, may be a silly ? but were you using the water lines? Fingers crossed for that $450 exchange program. |
Re: RIP GT3076R :(
(Post 46890181)
I was using the water lines. The feed line is a -3an and it has oil dripping out of it. The return is -10an. The CHRA looked wet where the feed was connected. I'm wondering if I need to somehow install a gauge to confirm that it is getting good pressure at the end of the line. The Garrett dealer may also be able to shed some light on why it failed.
Fingers crossed for that $450 exchange program. since the housings are still intact, I think you should be able to qualify for the exchange. |
Re: RIP GT3076R :(
I really want to see you upgrade to the GTX :)
Re: RIP GT3076R :(
Originally Posted by Muckman
(Post 46892912)
Who knows, if I get wind of a bonus at work I may end up putting the repaired GT30R on the s2000 and break the bank for the GTX3076R. The s2000 is going to have me driving to Jacksonville, FL to see MASE for a tune in the spring anyways. I've been thinking about throwing in one of those new in tank 340lph pumps on the integra and turning up the fuel pressure on my ID1000s to run e85. 650whp in the teg would make for some fun summer highway racing. |
Re: RIP GT3076R :(
(Post 46890181)
Re: RIP GT3076R :(
Originally Posted by 1quick-teg
(Post 46893976)
Where did you call for this exchange? I called a place in Tampa and they said all they can do is use my core for $250 off a new turbo...forget that I'd rather have it rebuilt.
3581 W. Electra Lane Glendale, AZ 85310 (623) 376-2562 info@turbosdirect.com http://www.turbosdirect.com I just shipped my turbo and it will be there on Thursday. He said a sales person will call me back once they inspect it and confirm it is eligible for replacement. |
Re: RIP GT3076R :(
Thanks alot..I'll give it a shot....
Re: RIP GT3076R :(
How much power did you make with this turbo anyways?
Re: RIP GT3076R :(
(Post 46905831)
So I got the badnews on Friday and I'm trying to convince myself to spend $1400. The CHRA on my GT30R is a total loss. The housings can be reused after they are cleaned up I'm told. It was starved of oil and it took out both the wheels. Luckily all the bearings were accounted for counting the 3 that fell out. I was offered a new CHRA for $725 or I can purchase the GTX3076R and reuse my old turbin housing. So unfortunately I have a mystery on my hands and until I get that solved I'm going to be nervous to put a $1400 turbo back on it. I'm buying a -3AN to 1/8 NPT adapter for an oil pressure gauge this week. Once I get that hooked up to the feed line I'm assuming I will see extremely low if any oil pressure. I'm not really sure what's causing it as I'm using oil pressure sender block fitting that came with my first XS Engineering turbo kit. It's brass and similar to the one below. I'm not really sure how that could of failed. |
Re: RIP GT3076R :(
I put a oil pressure gauge on my -3AN oil feed line. Since I didn't have an exhaust manifold on I didn't run it very long. Car built 80psi pressure within a few seconds and we noticed the -3AN feed got up to 60psi until I shut it down.
Looks like my oil feed line is good. I'm going to drop the pan to just look around and play it safe. What a mystery... Looks like I'm going to go the cheap route as I can't roll the dice that it won't happen again with a $1400 turbo. |
| All times are GMT -8. The time now is 09:18 AM. |
