ring gap clearance
Old Mar 11, 2012 | 04:15 PM
1994turbocivic's Avatar
Default ring gap clearance
would .015" first ring, and .016" second ring be good for a d16z6 75mm mid comp boost build?
Old Mar 11, 2012 | 09:15 PM
LowBudgetBEe's Avatar
Default Re: ring gap clearance
.015 top and .018 second would be better
Old Mar 12, 2012 | 04:34 AM
sleepencivic's Avatar
good article from Laskey:
Assuming the bore is 3.189 inches, set the gaps as follows:
Upper ring gap
006" x 3.189 = .019" (Turbo engines only)
Second ring gap
0065" x 3.189 = .021" (Turbo engines only)
Note: The above numbers are for an 81mm engine (3.189"). You will need to adjust your calculations based on the size engine you are building.
Oil rails....
Don't adjust the gap on the rails, just make sure it's between .010" to .050". Just check one, not all eight as this is not a critical measurement. If one is within spec, they all will be in spec.
All measurements listed here are in inches, not millimeters. If your rings already have a much bigger gap, they are the wrong rings. If the rings overlap each other, they are way too big and are the wrong rings. Contact the company that supplied them to you. Do not try to fix them by grinding that much off.
If one of your ring gaps winds up at .022", it's not the end of world. Just remember, it's easier to take it off than put it on.
The important thing when measuring the gap is to be sure the ring is perfectly centered in the cylinder and straight. Spray cylinders with WD40 before putting ring to be gapped in the cylinder. Once in the cylinder, use the top of a piston to push the ring down about an inch, keeping the piston straight in the bore. Be careful if you are using a piston with a dome so that you are not hitting the dome when aligning. That could make the ring sit off center in the bore.
Do the second ring gapping procedure first as they are a much softer ring than the upper ring and take very little filing to remove several thousandths.
Also remember to deburr the area you filed before doing the final install of the ring onto the piston. If you don't do this two things will happen. One, you will scratch the cylinder wall and two, the ring will not be able to spin freely when installed on the piston. The best deburring tool is a cheap and small knife sharpening stone. They are about $3 at most hardware stores.
If you do not have a ring gapping/grinding tool, here is an easy way to file the rings. Take a smooth metal file and lock it in a bench vise. Gently place the gap around the file and pull the ring toward you. Important: File only ONE side of the ring and not both sides at the same time. You want to keep both sides of your gaps as close to parallel as possible. If you only work with one side, you will have the other side perfectly straight to compare with. Re-measure the ring gap and proceed accordingly. Be sure to deburr the ring with a smooth stone when the gap is set.
Old Mar 12, 2012 | 05:38 AM
thanks for the info
Old Mar 12, 2012 | 06:12 AM
Muckman's Avatar
Moderator in Chief
What if your middle rings are too big of a gap without being filed? Ive run into this both with new CP and Wiseco rings. Both manufacturers say its not a big deal and its actually better to have a bigger middle ring gap to prevent ring flutter. If this is true then why do they even have a calculation for the middle ring?
And how important is the RATIO between the top and middle ring? If you target a multiplier of .006 top and .0065 middle but your middle gap works out to be .007 unfiled should you increase the top ring multipler to maintain the ratio? Ie .0065 top/.007 middle Or keep the original .006 top multipler?
Old Mar 14, 2012 | 05:48 PM
this is something i would like to know also. i too have also had second rings to big out the box
Old Mar 24, 2012 | 06:04 PM
any second opinions???
Old Mar 24, 2012 | 10:23 PM
Dc4LsTeG's Avatar
EK9
Muckman is right. If you want some more info check out my thread in here, it has some really good info on ring gaps
Old Mar 25, 2012 | 10:54 AM
yea thanks alot, really good info on there
Old Mar 25, 2012 | 10:57 AM
Spawne32's Avatar
im running .015 and .018
Old Mar 25, 2012 | 11:37 AM
sde780's Avatar
I'm running .019" and .021" on my 75.5mm Vitara build
Old Mar 25, 2012 | 05:20 PM
that is what i plan on running, what is your setup?
Old Mar 25, 2012 | 06:42 PM
Spawne32's Avatar
84.5x89 11.5:1 compression boosted
Old Mar 25, 2012 | 08:08 PM
Muckman's Avatar
Moderator in Chief
You and I are both running identical engine setups. Except my rings wont butt ends
Old Mar 25, 2012 | 08:11 PM
Dc4LsTeG's Avatar
EK9
Old Mar 25, 2012 | 08:16 PM
Spawne32's Avatar
har har, im not running a turbo, so i followed street performance specs
Old Mar 26, 2012 | 02:45 AM
Muckman's Avatar
Moderator in Chief
Oh I thought you said boosted. That makes more sense now.
Old Mar 26, 2012 | 07:22 AM
Spawne32's Avatar
supercharger
Old Nov 30, 2023 | 09:59 AM
StainedEngine's Avatar
Isn’t that kind of a tight gap for a turbo charged engine, NA engines r supposed to have that kind of gap.
Old Nov 30, 2023 | 12:54 PM
DaX's Avatar
DaX
Loved
Community Favorite
You're about 12 years late to the party.
Dc4LsTeG
Engine Machining & Assembly
120
Sep 27, 2024 08:56 PM
Johnoolo
Jan 16, 2018 08:52 PM
Bubba Zanetti
Apr 13, 2010 02:53 PM
LSVtechnologytur...
Feb 13, 2005 10:56 AM
Ri5e
Aug 3, 2002 10:51 PM
