Ring Filing Questions....
Old Dec 8, 2002 | 03:59 PM
niedejb's Avatar
Default Ring Filing Questions....
Was filing my rings today (F22b1 turbo app) and have 3 questions:
1) Does the ring labelled seperator in this pic get filed? There are no instructions for the expander/seperator ring. Damn thing is flimsy and doesnt want to fit in the cylinder to allow measuring. Does its geometry account for thermal expansion and not need filing?
Heres the info I have:
2) All the oil rails were all too big >.015" prior to any filing...ranged from .016 to .026". The instructions say minimum gap is .015" is this too big? Do I need a smaller size?
3) The ring gap alignment info does not match my honda service manual. Do I use this one or the info in my manual. The manual states not to align any gaps on the thrust surfaces, yet the JE/SRP info says to....
Manual:
JE/SRP:
Which would you use?
Looking for guidance.
[Modified by niedejb, 7:00 PM 12/8/2002]
Old Dec 8, 2002 | 05:25 PM
Farnsrocket's Avatar
Default Re: Ring Filing Questions.... (niedejb)
I used the JE gap instructions for the positions of the gaps (ignoring the service manual) and did not file any of my oil rings.......including the waffle ring that goes in between the two oil rings.
Old Dec 8, 2002 | 05:27 PM
niedejb's Avatar
Default Re: Ring Filing Questions.... (Farnsrocket)
What did the oil ring gaps measure? Do you remember?
Old Dec 8, 2002 | 05:47 PM
Ah, I can't remember. I have 84.5mm pistons. Sorry. Earl told me to never file them.
Old Dec 8, 2002 | 06:44 PM
turbohonda's Avatar
Never file any of the oil rings, only file the top and second ring. In my opinion the JE suggestion for ring gap comes up a little tight but I guess it all depends on how hard you push the motor.
Old Dec 9, 2002 | 05:21 PM
niedejb's Avatar
Default Re: Ring Filing Questions.... (turbohonda)
Thanks for the info.
Called raceng.com (supplier) and asked them if the oil ring "seperator" should have any gap. They said yes (.015"). I asked them if I should have to file it they said no.
When I put that ring in the bore, it pushes itself out of shape due to it being too large.
Still confused. May just have to put it in and hope for the best.
Old Dec 9, 2002 | 05:39 PM
Are you sure you have the right size rings? How were the top rings? How much did you have to file??
Old Dec 9, 2002 | 05:43 PM
niedejb's Avatar
Top rings started at .006" filed them to .020"
Second rings went from .006" to .015".
The oil rings range from .016 to .024" (havnt filed any of these either since the gap recommendation is .015").
So with the top two I would assume I have the correct ones, but the oil rings and the seperator have me wondering.
Old Dec 9, 2002 | 10:48 PM
sporkcrx's Avatar
In old chevy blocks etc. we never touched the wavy oil ring. And now for my curious question...why would the top manual state to never position a gap at the thrust points of the piston, while the other instuctions put the two compression rings in those spots???
Old Dec 9, 2002 | 10:57 PM
earl's Avatar
Default Re: Ring Filing Questions.... (sporkcrx)
Notice the JE paper says MINIMUM of .015. Basically the upper and lower rails just support the center piece and clearance not critical as long as you don't put the gaps right over each other.
Old Dec 10, 2002 | 02:27 AM
niedejb's Avatar
Wish I knew.
Nocture
Sep 14, 2010 07:45 PM
mrdeadman
Apr 17, 2006 07:29 PM
niedejb
Dec 8, 2002 08:10 PM
KF_S2000
Nov 30, 2001 06:44 PM
