Revlimiter at 5000rpm !!!!!!!!!!??????????
Old Jul 9, 2002 | 12:17 AM
senpai's Avatar
Default Revlimiter at 5000rpm !!!!!!!!!!??????????
Ok, I got D16Y8 with A'pexi kit, no intercooler, VAFC, 450cc injectors, 255lph fuel pump. When cruising on the highway, after punching my car a few times...my car will start hitting the 'revlimiter' at 5000rpm. If I then let it cool down afterwards, it's okay again. It is warm lately, but will that make my car cut out like that? It's only pushing 4psi right now.
Can it be a faulty VAFC install? It worked fine before and it still seems to be.... Can the IAT sensor be the cause? It's currently sandwiched between the filter and filter pipe.
Old Jul 9, 2002 | 08:28 AM
senpai's Avatar
Default Re: Revlimiter at 5000rpm !!!!!!!!!!?????????? (maztur)
ttt
Old Jul 9, 2002 | 08:39 AM
Eyewitness's Avatar
check the oil???
Old Jul 9, 2002 | 08:42 AM
senpai's Avatar
Default Re: Revlimiter at 5000rpm !!!!!!!!!!?????????? (Eyewitness)
oil can do this? how?
Old Jul 9, 2002 | 08:48 AM
Eyewitness's Avatar
i know the secondary butterflies and vtec dont work if oil is too low...just offering a possible problem..
Old Jul 9, 2002 | 10:12 AM
PyroVTEC's Avatar
New User
Reset the ECU. I had that happen once w/ my Greddy turbo D16 after a particularly long boosting pull and motor wouldn't go above 5000rpm. After you reset the ECU, it should be OK.
BTW, SOHC VTEC motors have no secondary butterflies.
[Modified by PyroVTEC, 11:13 AM 7/9/2002]
Old Jul 9, 2002 | 11:17 PM
senpai's Avatar
Default Re: Revlimiter at 5000rpm !!!!!!!!!!?????????? (PyroVTEC)
nonono, it does it for awhile then if I let the engine cool down, it's okay again. I don't have to reset anything.
I am wondering why it'd do this in the first place.
Old Jul 10, 2002 | 08:22 AM
Eyewitness's Avatar
Excuse my ignorance...i didnt read the post clearly obviously....
Old Jul 10, 2002 | 09:16 AM
inspyral's Avatar
check your AFC wiring. Did you move your VTEC engagement a lot? Sometimes that'll make it hit the early rev limiter.
Old Jul 10, 2002 | 05:19 PM
senpai's Avatar
Default Re: Revlimiter at 5000rpm !!!!!!!!!!?????????? (inspyral)
I'll check the VAFC wiring, but it's been perfect working order. What did you do about your IAT sensor?
Old Jul 10, 2002 | 05:58 PM
inspyral's Avatar
I drilled a hole in my charge piping and put a grommet in. It'd probably be better to relocate it to your intake piping, but I left mine hanging for about a year before I put it in my charge piping.
SkIp_Civic_Ek6
10
Jun 11, 2006 05:11 PM
UPYOURZ
Dec 23, 2005 06:33 AM
Hellz99si
Sep 17, 2002 05:38 AM
pushin redline 6
Mar 5, 2002 07:20 PM
dragster
Nov 1, 2001 04:47 AM
