Rev Hard Question
Old Jan 18, 2003 | 10:56 PM
RyanAutry's Avatar
Default Rev Hard Question
They claim 14whp for every pund of boost.
I dyno'd 133 stock b16a.
I plan on running 11psi.
11 x 14 = 155whp + 133whp = 288whp.
Right?
I figured only 250whp out of 11psi?
Mods
- 99 Si B16A2 Engine 10.2:1 cr
- Rev Hard Stage 2C Turbo Kit 11psi
- Rev Hard 2C Intercooler (32x8x3.5)
- Rev Hard Iron Tubular Turbo Manifold
- Nutec T3/T04E Turbo 60 trim
- Tial 35mm Wastegate
- 2.5" Downpipe
- 2.5" Test Pipe
- 2.5" Greddy Power Extreme Cat-Back Exhaust
- 2.5" Aluminum Charge Pipe
- 2.25" Aluminzed Mandrel Bent Piping
- HKS Sequential BOV
- Hondata Stage 2B Engine Managment
- P30 ECU
- RC 440cc Injectors
- ACT 6 puck Clutch
- Lightened Flywheel
- Walbro 255lph Fuel Pump
- B&M Fuel pressure regulator
Old Jan 18, 2003 | 11:01 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Rev Hard Question (RyanAutry)
I honestly think you will get closer to 300whp at 11psi. BTW, ever get the pic of that NUTEC turbo? I have a feeling its actually a Precision turbo.
art
Old Jan 18, 2003 | 11:03 PM
RyanAutry's Avatar
Default Re: Rev Hard Question (Arturbo)
Me kit should be here soon.
I promise you will be the first one to see the pics art...
If I get close to 300. I think I'll back it down a few psi...
I don't really want more then 280 on the stock motor.
Old Jan 18, 2003 | 11:07 PM
LS-hatch's Avatar
with 10.2:1 and 11 psi, I would expect at least 275 out of your setup, if not a little more. Good luck on dyno day.
Old Jan 18, 2003 | 11:17 PM
RyanAutry's Avatar
Old Jan 18, 2003 | 11:40 PM
IntegD's Avatar
New User
This is off topic as hell..but that smiley rules. How can I save it or create it so I can use it on posts?
Old Jan 19, 2003 | 09:28 AM
tony1's Avatar
I don't see how they can claim 14 hp for every pound of boost. There are way to many variables to put a number on it like that. Either way though, your car should make alot of power at 11psi!
Old Jan 19, 2003 | 11:23 AM
redline201's Avatar
Default Re: Rev Hard Question (tony1)
11psi on a stock block
you got *****
good luck
Old Jan 19, 2003 | 11:26 AM
RyanAutry's Avatar
I don't know either. Just repeating what i've read.
Originally posted by Rev Hard Mfg.
Beware of other kit manufacturers claiming 100 horsepower gain (to the wheels x15%=115mhp) with their bolt on kits. Any turbo expert can tell you that it would take e VERY efficient turbo to get 7x14hp=100. This means their turbo is getting close to 15hp for every psi of boost. We'll tell you up front that we can't beat that if it's true. And we'll also tell you upfront that those intercoolers and turbos they have will not support 300max.
THIS IS THE REASON WHY MAGAZINES WILL NOT DO A TURBO KIT OR MANIFOLD CHALLENGE...THEY MIGHT LOSE ADVERTISING TO WHO EVER SELLS NON-REV HARD KITS.
Old Jan 19, 2003 | 01:30 PM
RyanAutry's Avatar
Default Re: Rev Hard Question (IntegD)
Just copy the link and bookmark it.
Old Jan 19, 2003 | 02:17 PM
TurbothisLS's Avatar
Default Re: Rev Hard Question (redline201)
11 psi with a t3/t04e on a high compression motor might not be such a good idea
get it tuned correctly is all i can say
Old Jan 19, 2003 | 02:26 PM
ReVtecSi's Avatar
my friend got his revhard a little bit ago and it came with the Precision turbo
Old Jan 19, 2003 | 02:30 PM
RyanAutry's Avatar
Default Re: Rev Hard Question (TurbothisLS)
No Problem...
If st00pid can run 20psi on a LS motor w/pump gas. Then I feel confident.
Plus I ran 11 - 13psi for over a year with the JRSC.
Old Jan 19, 2003 | 02:36 PM
DIRep972's Avatar
Smarter than you
I think youll be fine AND make good power. 14whp per psi may be a good guess but that # is gonna change as ur turbo goes in and out of efficiency.
[Modified by DIRep, 3:36 PM 1/19/2003]
Old Jan 19, 2003 | 02:37 PM
RyanAutry's Avatar
11psi w/ 10.2:1 = 17.8 effective compression ratio.
14psi w/ 9.2:1 = 17.9 effective compression ratio.
Old Jan 19, 2003 | 02:41 PM
RyanAutry's Avatar
Default Re: Rev Hard Question (DIRep)
Well all I want to truely make is at least 260. That should me good for mid-12's.
Old Jan 19, 2003 | 02:46 PM
RyanAutry's Avatar
Old Jan 19, 2003 | 03:12 PM
SiRkid's Avatar
Old Jan 19, 2003 | 03:30 PM
simike's Avatar
you got *****
good luck
I hear you! I am running 8lbs on my stock B16A2 and i feel nervous sometimes.
Old Jan 19, 2003 | 03:43 PM
RyanAutry's Avatar
you got *****
good luck
Stock Engine is good for 300whp with a good tune...
How much boost run doesn't matter. It's how much power the motor makes that's important.
Old Jan 19, 2003 | 05:49 PM
RyanAutry's Avatar
Old Jan 19, 2003 | 10:25 PM
revhardsales's Avatar
We didn't say we make this power. That's why we said BEWARE of others claiming this kind of figures. Then again you might want to dyno your car at that place in Alhambra. You might get 20hp per psi. Good Luck and let us know how it went. By the way anyone interested in turbocharging their 2002-up RSX and CIVIC's call us cause where taking orders for special introductory price. Finally, the fueling all solved.
Old Jan 20, 2003 | 06:41 AM
redline201's Avatar
you got *****
good luck
is this true???
Old Jan 20, 2003 | 07:57 AM
LS-hatch's Avatar
you got *****
good luck
is this true???
Partially, i can make 20 hp and blow my motor from too much boost. However adding a bigger exhaust will add hp but will not add much load onto the engine.
Old Jan 20, 2003 | 08:19 AM
Brandon's Avatar
Life is Suffering
Default Re: Rev Hard Question (LS-hatch)
I don't mean to hijack, but could someone give me Rev Hard's website?
