Is the resistor box really necessary?
Old Jun 3, 2004 | 09:47 AM
fjt's Avatar
fjt
Default Is the resistor box really necessary?
Heres the scenario.. OBDII car, D16 motor and DSM blue tops injectors. I've been reading and seems like everyone is running a mandatory resistor box for the DSM to work on 92+ Civics.
I havea Friend with the DSM inj. on hos 98 civic and he did not used a resistor box or check valves. He just got the clips to be able to bolt the injectors in there and thats it.More than a year running them w/o any trouble. Whats up with that?
I am going to be doing almost the same setup and im wondering if it will work or not.
Old Jun 3, 2004 | 09:52 AM
wisjdmhonda's Avatar
Default Re: Is the resistor box really necessary? (fjt)
i think it fries the ecu if you dont use them
Old Jun 3, 2004 | 09:55 AM
99B16Si's Avatar
the wrong current going to the injector drivers in the ecu is not good and will fry them over time
Old Jun 3, 2004 | 10:10 AM
Pengo's Avatar
saturated vs peak and hold.
u need that resistor box if u want those injectors to work properly.
Old Jun 3, 2004 | 12:43 PM
baphomet's Avatar
yes you need one. Your stock injectors are high impedance the dsm are low impedance.
I have a few PM me if you need one.
Old Jun 3, 2004 | 01:27 PM
drvfast's Avatar
Or you can pick up some 10watt 10ohm wirewound resistors from radio shack.
Old Jun 3, 2004 | 06:45 PM
Muckman's Avatar
Moderator in Chief
They probably wont even work if you dont use it. Its not really an option.
evosix
Jun 4, 2008 06:41 PM
food
Dec 29, 2007 06:49 PM
sivik2nr
Jun 11, 2003 09:59 PM
2K_TEG
Jun 2, 2002 09:28 PM
