Replace oil pump or not?
Old Nov 12, 2003 | 04:26 PM
VanHonda's Avatar
Default Replace oil pump or not?
I am having my block re-sleeved and there is about 55,000 on it. While I have the engine out of the car is it necessary to replace the oil and water pump? There will not be a lot of boost imidiately, but soon enough there will be. Should I just do it while the motor is out?
Craig
Old Nov 12, 2003 | 04:28 PM
poison's Avatar
Default Re: Replace oil pump or not? (VanHonda)
You should be perfectly fine, but preventative maintenance is always a good thing.
Old Nov 12, 2003 | 04:32 PM
PM-Performance's Avatar
Default Re: Replace oil pump or not? (poison)
you dont have to, but its easier to do while the motor is out, i rebuilt mine at like 40k or so and reaplcedmine,. .its only an additional $200 or so and is worth it.,
Old Nov 12, 2003 | 06:02 PM
ekb18c's Avatar
Change it!! Better safe then sorry.
Old Nov 12, 2003 | 07:32 PM
5thgencivic's Avatar
Default Re: Replace oil pump or not? (ekb18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb18c &raquo;</TD></TR><TR><TD CLASS="quote">Change it!! Better safe then sorry.</TD></TR></TABLE>
I agree. One less thing to worry about.
Old Nov 13, 2003 | 03:25 AM
VanHonda's Avatar
Default Re: Replace oil pump or not? (5thgencivic)
Ok, I'm gonna go ahead and change it. So the next question is...Is the factory replacement best like most other things? And I just need the gear right?
Old Nov 13, 2003 | 03:30 AM
OEm is best and you need the whole pump
Old Nov 13, 2003 | 03:58 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Replace oil pump or not? (itr206)
Replace it!! And use an OEM from your local dealership. I think its funny when people think that the OEM pump will shatter at high rpm. It will, but what people fail to realize is why it shatters at high RPM's. Virbrations are your engines worst enemy! Always use a stock pump and make sure everything in your enigne is balanced and have a good harmonic dampaner too.
art
Old Nov 13, 2003 | 04:55 AM
99lspwr's Avatar
Default Re: Replace oil pump or not? (Arturbo)
arturbo:::so I guess you are not a fan of unorthodox racing crank pullies...I just put one on to give it a try..I heard from some people that since the honda crankshafts are internally balanced to 0, a lightweight pulley will not matter.....
92integraVTECgsr
Jan 28, 2007 08:25 PM
UK_Luder
Nov 14, 2006 05:33 PM
johng
Mar 30, 2006 06:53 AM
Trak_Day
Jan 21, 2004 09:04 AM
Ek00fbp
Dec 25, 2003 04:54 PM
