Removing intake manifold gasket
Old Nov 29, 2003 | 07:31 AM
BringIT's Avatar
Default Removing intake manifold gasket
Anyone have any tips to remove an intake manifold gasket that has been baked on? I'm using a gasket remover and an exacto knife. But there are still a lot of bits stuck all over it. Any way to speed this up?
Old Nov 29, 2003 | 07:46 AM
Bailhatch's Avatar
Default Re: Removing intake manifold gasket (BringIT)
die grinder with 3m scuff pad = 1 minute job and clean smooth surface.
Old Nov 29, 2003 | 07:47 AM
Ri5e's Avatar
Default Re: Removing intake manifold gasket (Bailhatch)
Gunk remover and a box cuter (Be careful not to knick the surface)
If there are still tiny bits still stuck , use fine grit sandpaper
Old Nov 29, 2003 | 08:10 AM
Blue Streak's Avatar
its a bitch, i usually use gasket remover and let it work for a while then start scraping, you're gonna have to do it a few times to get it all off.
Old Nov 29, 2003 | 10:02 AM
shortyz's Avatar
Default Re: (Blue Streak)
guys can u put graphite on the gasket before u install it to keep it from sticking..
thats what we do on high heat steam flanges..
i want to try it on a gasket some time.
Old Nov 29, 2003 | 10:53 AM
Foozball26's Avatar
Default Re: (shortyz)
get some carb cleaner, that will break it down and make it easy to scrape off.
you may want to look into a fel-pro intake mani gasket, they don't stock to the surfaces so you can just reuse it.
aryiman98civic
Feb 24, 2007 07:02 PM
boosted ek
Jun 27, 2005 07:01 PM
253EK
Jun 10, 2004 10:16 PM
MR. MIYAGI
Mar 26, 2004 08:01 PM
dualknuttz1
Jan 23, 2004 08:37 PM
