Removal of an FMU
Old Aug 4, 2002 | 09:47 AM
shadowdawn's Avatar
Default Removal of an FMU
I will be getting 440cc brand new rc's in this week and will be putting them in and taking the FMU out.... was just wondering how I could go about reconnecting those fuel lines? Just but a brass fitting from homedepot and clamp it on between the two? Is that it?
Old Aug 4, 2002 | 10:30 AM
highmilehatch's Avatar
Default Re: Removal of an FMU (shadowdawn)
I'm assuming you have a vortech fmu. If so, remove the fuel line from the factory fpr going to the side of the fmu. Now remove the the fuel line from the bottom center of the fmu and reattach that line to the factory fpr. Your done!
Old Aug 4, 2002 | 10:35 AM
shadowdawn's Avatar
Default Re: Removal of an FMU (turboeg)
Thank you v-much, I thought the ideal method was to replace a whole line back to the tank, didn't realize it was going to be that simple :D
Old Aug 11, 2002 | 04:22 PM
v63000gtv6's Avatar
Are you selling your fmu? If so how much? I need one soon. I also live in New Jersey. What part are you from? I live in Cranford. That's in upper central New Jersey.
-Sean
Old Aug 11, 2002 | 06:14 PM
shadowdawn's Avatar
Default Re: Removal of an FMU (v63000gtv6)
I live in passiac county northern NJ, I am selling it soon hope to get injectors THIS week so once I do and install them I will be selling the FMU (with a 12:1 disc in there) plus the whole recalibration kit (all the discs you would ever need), probably looking to get $100 for all that together, pm me for more details.
Old Aug 11, 2002 | 06:30 PM
FAUCON's Avatar
Now that you got 440cc injector, you dont need an FMU? Is it right?
Old Aug 11, 2002 | 06:44 PM
shadowdawn's Avatar
Default Re: Removal of an FMU (FAUCON)
That is correct I will only be using a FPR, and S-AFC to tune the fuel mixture, no more need to use the fmu as you can run probably up to 9-10psi with 440cc's and afc alone with correct tuning of course... after that you SHOULD get standalone but some people use big injectors + afc + fmu to get the fuel there...
Old Aug 12, 2002 | 04:54 PM
FAUCON's Avatar
And how will you tune your AFC? On the dyno? or just how it work well or not(push hard)?
CTR_B
Jun 2, 2008 10:51 AM
VI Boost
Nov 27, 2007 03:04 AM
ID_ten_T
Aug 17, 2003 11:45 PM
flip1199
Jul 21, 2002 04:46 AM
2K1NBGSR
Jun 11, 2002 06:56 PM
