Recognizing GM Map Sensor
Old Dec 1, 2002 | 07:45 AM
philo's Avatar
Default Recognizing GM Map Sensor
I have two GM Map Sensors but I cant tell if they are 1, 2 or 3 bar. They have some numbers stamped into them but none match up to the part numbers I have for GM Maps. Maybe one of you will recognize these numbers.
Map 1: 886 3168
Map 2: 039 5128
Old Dec 1, 2002 | 08:11 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: Recognizing GM Map Sensor (philo)
yo man, i have a GM 3Bar map sensor and the numbers on the back say 749 7316, so i guess you have a 1 and 2, im guessing, i would get a second opinion, but i figured id go downstairs and look for ya, good luck, RON
Old Dec 1, 2002 | 10:33 AM
philo's Avatar
Default Re: Recognizing GM Map Sensor (SIXTYdashONE)
I suspect one is a 1 bar and one is a 2, thanks a lot for looking. I want install the 2 bar if I can just work out which one it is.
Old Dec 1, 2002 | 02:54 PM
Lei Siew Long's Avatar
mine says 749 7218 and it is a 3 bar map sensor
Old Dec 1, 2002 | 03:55 PM
philo's Avatar
Default Re: Recognizing GM Map Sensor (boostedeg6)
It seems like the first three digits of the number stamped on the back designates how many bar it supports.
1bar: 039
2bar: 886
3bar: 749
Old Dec 1, 2002 | 08:04 PM
HT's Biggest Loser
no prob man, good luck
Old Dec 1, 2002 | 08:53 PM
boostaholic's Avatar
If you still need help finding a GM 3 bar map sensor, go to any autoparts store that carries AC Delco parts and ask for part number 213-101.
Old Dec 2, 2002 | 06:30 PM
swrdply400mrelay's Avatar
how come when i go to http://www.gmpartsdirect.com i can't find it? where did you guys get yours?
boostedeg6
SIXTYdashONE
which number is right? neither of these numbers find any parts. hondata doesn't say what part number either
any help would be greatly appreciated
Old Dec 3, 2002 | 07:34 AM
Default Re: Recognizing GM Map Sensor (swrdply400mrelay)
bump
Old Dec 3, 2002 | 08:37 AM
justagsr's Avatar
this should be it on gmpartsdirect.com: 16040749
young geezer
Aug 1, 2009 12:44 PM
KRWTEK1
May 28, 2007 12:32 AM
turbolshatch
Feb 2, 2006 06:06 AM
CiViC SiR
Jun 26, 2003 08:54 PM
89civic1.8T
Jul 4, 2002 03:47 PM
