recirculating bov's
Old Mar 2, 2006 | 06:48 PM
lalspeed's Avatar
Default recirculating bov's
has anyone used them before? know of any good ones? and also can you recirculate a open atmosphere bov back in to the intake? thanks in advance
Old Mar 2, 2006 | 06:52 PM
GS-R Civic's Avatar
Default Re: recirculating bov's (lalspeed)
no need to recirculate on a honda... MAP>MAS
Old Mar 2, 2006 | 06:53 PM
deadlock32's Avatar
is there a point to recirculation bovs other than to quiet them down?
Old Mar 2, 2006 | 07:01 PM
GS-R Civic's Avatar
Default Re: recirculating bov's (deadlock32)
Its necessary for cars with a mass airflow sensor such as dsm's or subbies I believe. But us honda guys have MAP so we do not need to recirculate.
MAS reads the amount of air that comes into the intake by the filter. Therefore the ecu is taking that air into account when determining the A/F ratio. If the air is blown out the the atmosphere the A/F raito gets messed up. So when you recirculate back into the intake the air is still being accounted for.
MAP reads the pressure inside of the intake manifold to determine the A/F ratio. Therefore the BOV "blows off" before the air is even read by the MAP sensor, so the A/F ratio is not affected.
That is my basic understanding of how this works. If anyone has anything else to add, or can correct me on anything please do!
Old Mar 2, 2006 | 07:14 PM
Boilermaker1's Avatar
Thats a fairly decient explaination of it.
the MAF has accounted for the air, so if you dump it, there's not enough air and the car blips rich for a split second.
MAP it doesn't matter.
I have a stock 911 Turbo one thats made for recirc, but no plans to recirc it unless the noise just gets annoying.
There's no benefit really on a MAP car other than noise reduction and I suppose that little puff of pressurized air gives a little spooling kick, but I can't see it being much.
Old Mar 2, 2006 | 07:16 PM
lalspeed's Avatar
Default Re: (Boilermaker1)
the reasoning behind it is noise reduction in my case atleast.
Old Mar 2, 2006 | 09:31 PM
GS-R Civic's Avatar
Default Re: (lalspeed)
If you are looking for noise reduction i have seen a bov online somewhere that is said it be "silent." Im not sure how well it work, but if thats what you are looking for I would hit up a search .
journeyquest
Aug 21, 2010 08:50 PM
iNvNONE
Engine Management and Tuning
Aug 19, 2008 05:23 AM
DOUBLExDEUCEx22
28
Jul 27, 2008 09:07 AM
vtecazo
Oct 31, 2003 11:47 AM
CovertFI
Jul 10, 2002 08:01 AM
