Rebuilt time !!!! RIP stock LS
Old Jul 7, 2012 | 04:36 PM
ChingaDEboost's Avatar
Default Rebuilt time !!!! RIP stock LS
Car just came from sitting for 2 years and went with a 6262 with topmount turbo setup made like 360 to the wheels lasted a 2 months and was driving it the other day drop oil pressure like crazy ... and as soon as i saw it hit 20 psi of oil pressure I turned it off i haven't completely looked in to it so I'm not sure what went wrong Im probaly gonna rebuild anyways i wonder should i go with stock sleeves and just do pistons and rods OR should I just do pistons/rod/ and GE sleeves ..??? what oil pump can i upgrade too on my b18 LS block ...i heard Type R but wasnt too sure .... what else should I replace since Im in there
Old Jul 7, 2012 | 04:40 PM
Default Re: Rebuilt time !!!! RIP stock LS
everyone is telling me to check the oil for shavings ... so Im gonna probably tear i apart .. i don't recall hearing any kind of knocking so i wonder if i threw a rod or just blew my oil pump
Old Jul 7, 2012 | 05:00 PM
ryguy2588's Avatar
If u have the money, sleeve it and do a fully built LS/VTEC, ie. pistons pistons, rods, vtec head, dual valve springs, retainers, itr or ctr or aftermarket cams and so on. You can use use a type r, gsr, or b16 oil pump, they're all the same. Your limit is how much you wanna put into it.
Old Jul 7, 2012 | 05:01 PM
ryguy2588's Avatar
If you threw a rod, there would be a hole in the block and you would see that lol.
Old Jul 7, 2012 | 06:47 PM
thid92's Avatar
can I haz?
i dont think you would have any oil pressure if throwing a rod and more than likely your car would have stalled. its could be a couple of things, bearings, oil line, head gasket or something else. I am only familiar to the bearings going.
Old Jul 8, 2012 | 08:09 AM
nealnanoHX's Avatar
Sounds like you spun a rod bearing most likely. On a LS motor you almost need ARP rod bolts at that power level or you risk stretching the rod bolts. Yes if you have the money have the block sleeved but forged pistons and H beam rods will handle 400whp ish on stock sleeves.
Old Jul 8, 2012 | 03:01 PM
GEN2 LS's Avatar
Loved
go with a rod/piston combo and the CSS blockguard.
Old Jul 10, 2012 | 09:07 AM
whats a CSS blockguard
Old Jul 10, 2012 | 09:23 AM
Spawne32's Avatar
New style of block guard where they CNC mill the sleeve at the top to seat the guard better so that it doesnt apply uneven pressure across all 4 cylinders.
Old Jul 10, 2012 | 09:44 AM
HickamHatch's Avatar
simple solution, buy a V6
Old Jul 10, 2012 | 09:54 AM
ill just let you waste your own time
Old Jul 10, 2012 | 09:56 AM
haha, i would just get a sleeved block. What crank pulley were you using?
Old Jul 10, 2012 | 10:26 AM
stock
Davidls
Mar 20, 2010 08:51 AM
SR20S13
Jan 19, 2010 04:25 PM
damndude_92
14
Apr 15, 2009 05:16 PM
Lsweez
17
Oct 1, 2007 05:48 PM
xmattoxx
17
Jan 12, 2003 01:47 PM
