RC injectors install...
Old Sep 26, 2002 | 05:48 AM
metal-x's Avatar
Default RC injectors install...
any tips on installing, on 95 gsr....
thanks
Old Sep 26, 2002 | 07:56 AM
BoM's Avatar
BoM
Default Re: RC injectors install... (metal-x)
u need to get a helms, do a search.
its basically
release the pressure to the rail, unbolt the rail, take the fuel line off.
remove the rail swithc injectors, dont' forget the orings and bolt back on.
Old Sep 26, 2002 | 08:13 AM
CzanSOHC's Avatar
Default Re: RC injectors install... (BoM)
-pull your fuel pump fuse out
-crank the car over a few times to clear the lines
-unbolt the fuel line from the rail
-unbolt the two bolts holding the rail down(this is on a D16, dunno about a b18c)
-pull injectors out
-coat the new orings w/ a small amount of motor oil
-push the new ones in
Old Sep 26, 2002 | 08:15 AM
brcivic411's Avatar
Default Re: RC injectors install... (CzanSOHC)
the new clips will also have to be put in.. soldering is the best option
thunderboy
May 28, 2008 08:00 AM
way2much
Mar 7, 2006 12:33 PM
nyo91
Apr 16, 2004 02:44 PM
FastNFurious
Apr 5, 2003 03:39 PM
Que_Lude
Dec 24, 2002 06:34 AM
