RC injectors
Old Dec 14, 2001 | 05:52 AM
fast4door's Avatar
Default RC injectors
has anybody found it hard to install a set of new RC injectors. and if so what method did you guys use to but them in. can i cant seem to get them in with the rubber boss that they come with. any help will help me alot thanks
Old Dec 14, 2001 | 07:01 AM
TypeRdude's Avatar
Default Re: RC injectors (fast4door)
if you are talking about the small oring on the top of the injector, you need to put a little motor oil on the oring and the opening on the fuel rail and slowly slide it in. Be careful not to tear the oring.
If you are talking about the rubber seal on the intake manifold, it doesn't insert, it just sits firmly on top of the gasket. You may need to use some washers under the fuel rail studs to space it to the desired height. Hope that helps. Also make sure you solder the wires to the new injector clips, don't use connectors.
Old Dec 14, 2001 | 07:39 AM
rtype11's Avatar
I order mine made for a denso rail and have no probs, just plug and play.
Old Dec 14, 2001 | 09:24 AM
fast4door's Avatar
Default Re: RC injectors (rtype11)
well wit mine it says to place the rubber boss on the intake manifol and place the injectores on the rail then just pop them in but they dont seem to fit into the rubber boss on the intake. it looks like the rubber boss is to thick to just pop it in. anybody else have this problem
EG_Type R
Jun 22, 2010 04:59 AM
b20beast83
Dec 16, 2008 11:08 AM
blakacintegra
May 22, 2007 09:18 PM
S13 slide
Dec 23, 2005 09:19 PM
Ri5e
Jan 4, 2002 09:20 AM
