RC injector problem....
Old May 23, 2007 | 04:52 PM
Flexin5's Avatar
Default RC injector problem....
aparantly, all RC injectors are made for OBD-1, and you require the RC clips to convert to OBD-2. i have a 94 integra LS which is definatly OBD-1. my RC750cc's came and when i try to put the injector clip on them they won't go in. this is because there's a divideor in the middle of the injector, however no dividor on my injector clip.
did i need the adaptor clips or did i get sent the wrong injectors? i'm looking to fire up my motor tomorow but i can't until i get this sorted out
Old May 23, 2007 | 05:28 PM
Joseph Davis's Avatar
Default Re: RC injector problem.... (Flexin5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flexin5 &raquo;</TD></TR><TR><TD CLASS="quote">aparantly, all RC injectors are made for OBD-0, and you require the RC clips to convert to OBD-2. i have a 94 integra LS which is definatly OBD-1. my RC750cc's came and when i try to put the injector clip on them they won't go in. this is because there's a divideor in the middle of the injector, however no dividor on my injector clip. </TD></TR></TABLE>
I fixed it for you.
Take some small sidecutters and nip out the center divider. No one will ever notice, and you won't hurt anything. Alternately, buy injector clips like a wussy.
Old May 23, 2007 | 05:40 PM
ladysman's Avatar
Default Re: RC injector problem.... (Joseph Davis)
JD is right on. Gotta cut it out with cutters or I used an xacto knife with a straight blade on the end. Don't waste money on new clips.
Old May 23, 2007 | 06:01 PM
non-VTEC's Avatar
make them fit!!
BUT i hope you have your ECU tuned or some kind of basemap on there tuned for the 750's or the engine will not run.....
Old May 23, 2007 | 06:07 PM
Flexin5's Avatar
^yea nick is coming by to burn me a basemap to get me to the dyno.
thanks alot for the help, i'll do that tonite and hopefully fire er up soon!
Old May 23, 2007 | 08:41 PM
Topdawgg's Avatar
even with just a basemap, I had a hard time gettin 750s to idle without a wideband...
good luck though
killerpenguin21
May 2, 2010 11:51 AM
vlc92189
21
Mar 6, 2009 12:06 PM
RTW DC2R
Jul 16, 2006 09:27 AM
B18 CYA
Jun 23, 2004 04:15 PM
SlamMan
Jun 13, 2003 04:41 PM
