Rc injector clips...... need help
when installing rc injectors on a obd2 honda i was told that i need to get the clips also, my question is do the clips plug into the obd2 injector plugs and then into the injector (almost like a obd2 convertor for the comp.) or do you have to cut off the stock injector plugs and attach those.
also if anyone has pics of the clips could you post them up so i could see what it looks like. thanks for the help.
if you are going to use the old injector back you don't cut but if you don't cut the old ones and solder the new ones in their place.
The injectors have no polarity so it dosen't matter how you soldered
ScrapinSi
Oct 19, 2003 03:58 PM
