radiator cap?
I'm changing my radiator cap to higher pressure, what kind of pressure should i use on a drag3 gs-r with fluidyne radiator? Do i need to change the thermostate too?
Thank You!
Thank You!
Is 25psi around 1.7kg/cm2? Do you know what company makes one like that? most caps i seen are around 1.35kg/cm2 and the euro R cap is 1.38kg/cm2, will 1.7 be better or just go with the R cap?
Cool, thank you so much!
Sorry I have 1 last question, if i put too much holes on the bumper and cool down the radiator too much, will that cause problem to the radiator or engine?
"My radiator died the next day after i made 3 huge holes on my bumper"
