Race gas??
Old Sep 12, 2005 | 06:02 PM
95accordLX-T's Avatar
Default Race gas??
Hey guys. Im about to dyno my car tomorrow with the new setup. For the experienced guys here.........where is the point in which u need race gas??
At what power level should i run race gas? 93 octane is readily available but sunoco stop selling 94 octane recently.
I heard race gas ***** up ur sensors and clogs ur fuel filther. I dont have a cat so i could care less about the issues with that.
I need some facts and opinions guys!
Thanx.
Old Sep 12, 2005 | 06:10 PM
s2kdre's Avatar
Default Re: Race gas?? (95accordLX-T)
the higher the octane the less chance of having detonation, on c16 u can run alot more timing to make more power, but u cant have alot of timing on 93, anythin over 450whp u should use c16, i've seen over 500whp on pump gas but its not safe,
Old Sep 12, 2005 | 06:12 PM
s2kdre's Avatar
Default Re: Race gas?? (jdmhonda)
and my car is tunned on crome, running open loop which eliminates the o2 sensors,
Old Sep 13, 2005 | 05:13 AM
Thanx a lot. Ill be on te dyno today and ill let u guys know how it went.
Old Sep 13, 2005 | 05:55 AM
turbosi03's Avatar
no, ledded race gas fouls your 02 sensor. but you get use unledded race gas (I think they make up to 109 octane) and no fouling.
Old Sep 13, 2005 | 06:24 AM
Dragline's Avatar
Default Re: Race gas?? (turbosi03)
Leaded gas will shorten your O2 sensor life but I would rather buy O2 sensors then A motor..
Old Sep 13, 2005 | 09:11 AM
project dc2's Avatar
Default Re: Race gas?? (dragline)
if you're going to drive aroudn on 93 octane. tune with 93 octain. reserve racegas for well .. a race tune because most gases out there ned a lot of additives to increase the octane. These additives dont combust as easy as lower octanes so they require more timing in order to work correctly.
so if you tune on 93 octane. an dget 115 octane at the track youll lose power cuz you dont have enough timing to fire it off.
turbociv
Sep 23, 2005 06:23 AM
ensracer
Honda S2000
14
May 3, 2005 10:49 AM
quik sol
Aug 14, 2004 09:12 AM
Gorm
Mar 30, 2003 10:10 AM
stupidfast
Nov 18, 2002 12:49 PM
