A/R... semi explained
I just found a pic to help my explanation.
Compressor A/R is determined by dividing the radius of the compressor housing by the smallest diameter of the compressor outlet . Exhaust housing A/R is determined by dividing the radius of the exhaust by the smallest diameter of the exhaust inlet . As the A/R numerically increases so does the housings ability to induce/exduce a specific volume of air. Lag and effective power range will also be affected by A/R changes. Look at the A/R pic below.
Pic was ganked from a post on RX-7 Forum.
A/R only matters when your turbo doesn't spool up quick enough and you need to change your housing, but that's why you buy the biggest one and a ball bearing center.
geeez
Rob
formula for determining trim
[(minor wheel diameter)x(minor wheel diameter) / (major wheel diameter)x (major wheel diameter) ] x 100= trim
T04E 60
[(2.290)(2.290)/(2.950)(2.950)] x 100= trim
(5.2441/8.7025) x 100= trim
.6026 x 100 = trim
60= trim
T04E 60
.6026 x 100 = trim
60= trim
T04E 60
.6026 x 100 = trim
60= trim
T04E 60
.6026 x 100 = trim
60= trim
T04E 60
.6026 x 100 = trim
60= trim
Great info!
T04E 60
.6026 x 100 = trim
60= trim
Great info!
flip that to determine turbine wheel trim
[(exducer)(exducer)/(inducer)(inducer)]x100 = turbine wheel trim
i am confused on what u guys mean by minor wheel diameter and such..
u mean from small fin to small fin and big fin to big fin?
i might be wrong.. but i think its the other way around
T04E 60
.6026 x 100 = trim
60= trim
Great info!
that is the compressor wheel formula
T04E 60
.6026 x 100 = trim
60= trim
Great info!
example:
http://64.225.76.178/catalog/comp_wheels.html - compressor sides
http://64.225.76.178/catalog/twheel.html - turbine side
http://64.225.76.178/catalog/thousing.html - turbine side
heres my turbocharger - T3/T04B S:
Specs for compressor: 1.904" - inducer, 2.750" - exducer - it says major but i guess its the same thing
(1.904 x 1.904) / (2.750 x 2.750) / 100 = 47.93 for turbine size which is i went with, but wish i had this formula at the time..
[Modified by vtec.dc2, 1:16 AM 1/15/2003]
I guess humor is't a good part of my personality. Sorry I was atempting to make a joke noticed the sarcastic
