quick wastegate question please help...
Old Apr 18, 2004 | 07:33 AM
bigedx's Avatar
Default quick wastegate question please help...
tial 38mm wastegate, right now i have the very top fitting open, and the side fitting connects to the fitting on the turbo... i was told its better to use the brake booster as a vacuum as opposed to the fitting on the turbo... is this true? if so, can i just pull the hose off the turbo and spice it into the brake booster? or do i need to put some kind cap on it ? thank you for your time
Modified by bigedx at 5:43 PM 4/19/2004
Old Apr 18, 2004 | 07:56 AM
stinker504's Avatar
If you remove the line from the turbo you will need to plug the hole.
Old Apr 19, 2004 | 08:41 AM
bigedx's Avatar
Default Re: (stinker504)
what would you suggest i use ?
Old Apr 19, 2004 | 08:49 AM
B18C1CYA's Avatar
Default Re: (bigedx)
i would use the brake booster you will get a more true boost signal to the wastegate and just cap the port on the turbo.
Old Apr 19, 2004 | 10:33 AM
dunkd's Avatar
brake booooooster
pjr710
Jun 8, 2008 11:48 PM
the.hamburglar
Aug 1, 2005 07:27 PM
dturbo
Apr 5, 2005 10:41 PM
lowpsi
Dec 21, 2002 01:48 PM
DIY_Racing
Dec 18, 2002 05:40 AM
