Quick and Silly Headgasket Question
Old Aug 29, 2005 | 06:42 PM
M.A.R.C.'s Avatar
Default Quick and Silly Headgasket Question
Well, under the assumption that all B-series VTEC headgaskets were the same I went to the local Honda dealer and grabbed a 99-00 B16A headgasket. I was looking up some info for a friend with the C-SpeedRacing.com compression ratio/displacement calculator and lo and behold... the B16 gasket is said to be .020" thick and the GSR gasket is .030". Now, it's a minor difference that according to the calc would only be like 0.2:1 cr difference but I'm also worried about how much it would affect the cam timing and whether or not it'd be wiser to run a thicker gasket for safety anyway. The motor is a darton sleeved 9:1 81mm gsr. Bottom line... should I just use the B16 gasket since I already bought it or should I get a GSR gasket?
Old Aug 30, 2005 | 04:11 AM
M.A.R.C.'s Avatar
Default Re: Quick and Silly Headgasket Question (M.A.R.C.)
morning bump
Old Aug 30, 2005 | 01:16 PM
M.A.R.C.'s Avatar
up?
Old Aug 30, 2005 | 01:27 PM
DaveF's Avatar
that is wierd, i thought they should all be the same
is it possible that teh compression calculator is messed up?
Old Aug 30, 2005 | 01:31 PM
M.A.R.C.'s Avatar
Default Re: Quick and Silly Headgasket Question (Dturbocivic)
that's what i thought... but according to the c-speed site. oh well... just gonna use it. i'm sure it will be fine.
rorik
Nov 16, 2007 06:44 AM
eh2-hb
Oct 13, 2005 10:01 PM
B16Civic93
Feb 17, 2005 10:31 PM
SpeedMonkeyRacing
Mar 10, 2002 12:09 AM
