Quick question: precision injectors in a gsr
Will precision 650cc high imp. injectors fit without any problems in a stock b18c1? I ordered some and got them in. I was expecting the short/fat style injector, but I was surprised to see the long/skinny style and it made me question whether it will fit or not.
People have used this combination before, right?
TIA
TIA
Precision is now using a Siemen Deka Mototron style injector now. (I tried to get a few people to use them a couple of years ago, but they freaked out like you did about them being "skinny".) They've modified the ends to be able to fit the standard honda 10mm o-ring, and 15mm Ring into the intake manifold. They are also the same length as the "fat" Rochester/Lucas injector that you're used to. They should fit fine.
Awesome, just needed a little reassurance. Thanks for the background info TheShodan..can't wait for that turbo to come in...
for the wiring clips that I bought for them...how do I know which factory wire to solder it to? They are both white on the precision clips...I believe the factory has a brown color for each injector, and then different colors for the rest..
all i did (like 4 days ago) was hold the clip right side up same as the old one and matched right wire to right wire and so on and it worked perfect. I also got the 650cc's and when i put them into my fuel rail i was like crap they dont fit. but i took the o ring off my stock injectors and just bolted the fuel rail on and they fit tight now so yes they work good man. I just installed my kit and got it tuned on monday.
Awesome, looking forward to it.
Yeah, I think that may have been what I have done in the past too, but I thought there might be a better way. Thanks man, that's exciting stuff. How does it feel?
