Quick Question.....HP capability of 2" charge piping?
300 I was told was the limit 2 inch will flow, by a very well respected tuner/driver (10 sec integra owner.)
I would probably listen to that guy, and it sounds reasonable.
Although, I think Drag and Revhard both use 2" and a portion of 2.25" piping, and I know Greddy uses 50mm and 60mm piping which is 2 and 2.25 and there are some guys using those kits are doing over 300.
I need to figure this out before I re-do my piping in aluminum. Changing stuff around with steel is no biggie but the Al is gonna run about $200 in materials alone.
I'm shooting for the fastest spool up possible, but making sure not to cut off my goals in the process
[Modified by Bryson, 10:58 PM 9/19/2002]
go with 2.25, good flow at lower boost and support a higher app as well...I have 2.25" all around
remember, boost is a measure of pressure, not volume...they're both plays critical role, so use your judgement....think about the amount of flow your turbo support as well...
stan
stan
I am using 2.5" piping on a d-series motor pushing 12 psi, does that sound like overkill to you?? What affect does bigger piping have on power and spool up time?
I thought most greddy piping was 2.5? Yes it is overkill yeah I would reccomend 2 .25 if looking for over 300 hp, Mplex if I was you I'd go 2 inch
