quick question! help!
Old Jun 4, 2007 | 10:00 PM
vietelement's Avatar
Default quick question! help!
the thing to adjust the BOV, does anyone know where i can obtain one of those?
Old Jun 5, 2007 | 08:41 AM
Default Re: quick question! help! (vietelement)
nobody knows ???
Old Jun 5, 2007 | 08:51 AM
Running925's Avatar
local hardware store
Old Jun 5, 2007 | 08:57 PM
Default Re: quick question! help! (Running925)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Running925 &raquo;</TD></TR><TR><TD CLASS="quote">local hardware store</TD></TR></TABLE>
hmm, so like for example, home depot would have a stud with a hex on the top of it ?
Old Jun 5, 2007 | 08:59 PM
eg crunkmonster's Avatar
u could always use a 10mm and nut
Old Jun 5, 2007 | 09:04 PM
Default Re: quick question! help! (eg crunkmonster)
guess i'll just do that, rather then have the boost leak... thanks guys appreciate it
Old Jun 8, 2007 | 02:06 AM
well, the place where the stud goes to adjust hard or soft, is stripped out... not sure what i can do, besides tap it ?
Old Jun 8, 2007 | 02:56 AM
BDogggUT34's Avatar
i had the same problem. I just tapped it one size bigger (its easy, its aluminum), got a long bolt and cut the head off with my dremel. Then put a small slit in the top for a flathead screwdriver and works perfect! And make sure you get the nut for it too and tighten it down.
DunkJDM
Jul 23, 2008 04:24 PM
B18Sleeper
Jan 26, 2007 07:22 AM
hinds90
Honda Motorcycles
Aug 17, 2006 10:55 AM
tekstyle
Apr 24, 2006 10:06 PM
s1ngle
May 10, 2004 09:02 AM
