quick n2o relay and solenoid question...
Old Jun 1, 2003 | 07:57 PM
untitled's Avatar
Default quick n2o relay and solenoid question...
ok we have a zex kit i need to know the following:
there are 3 wires coming off the module: red, black, and white. lmk if this is right:
red -> 12v
black -> ground
white -> tps?
which wire do i have to tap into on the tps? anyone have a diagram? the green one?
okay heres #2.
there is a purge valve solenoid with two wires coming out of it. i believe they goto the relay right? then the relay is hooked up to the switch in the cockpit?
Old Jun 1, 2003 | 08:48 PM
97hb's Avatar
Default Re: quick n2o relay and solenoid question... (88crx91integra)
White wire hooks to the red-black on the tps sensor.
Old Jun 1, 2003 | 09:06 PM
untitled's Avatar
Default Re: quick n2o relay and solenoid question... (97hb)
yea i figured that the tps tells the ecu a voltage so i used a digital voltometer to test all of them at idle thinking that the one i need to tap would be one with 1 volts at idle.
xero_xero
11
Jan 21, 2013 03:33 PM
DS_Vtec
Aug 21, 2007 12:04 PM
4thgenHB157
Feb 17, 2005 05:23 PM
G2turbo_terror
May 16, 2003 01:24 PM
