quick dp question
Old Jan 29, 2004 | 02:32 PM
5STAR3's Avatar
Default quick dp question
if i am going to be running 2.25" for the exhaust is there any reason to make the dp lager than 2.25"?
on that same note, anyone know the diameter of the hole in the flange? cause if it is bigger than 2.25" it would be easier to just make the dp the same size as the hole.
Old Jan 29, 2004 | 02:34 PM
redboost10's Avatar
Default Re: quick dp question (envision2teg)
the flange is 2.5"
Old Jan 29, 2004 | 02:41 PM
5STAR3's Avatar
Default Re: quick dp question (tgh99si)
where can i get a piece that converts 2.5" to 2.25"?
Old Jan 29, 2004 | 02:50 PM
redboost10's Avatar
try http://www.atpturbo.com i know they have transitions
Old Jan 29, 2004 | 02:51 PM
redboost10's Avatar
man i dont really know if you want a 2.25 dp
Old Jan 29, 2004 | 02:58 PM
5STAR3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgh99si &raquo;</TD></TR><TR><TD CLASS="quote">man i dont really know if you want a 2.25 dp</TD></TR></TABLE>
the only reason i want to do that right now is:
a. i have extra 2.25" pipe to use
b. i will be boosting low levels 5-6psi for now
c. i am keeping stock exhaust untill i up grade this summer.
so if i have a dp larger than 2.25 it wont make a difference because the rest of the piping will be stock?
those were my thoughts, but i am open to suggestions
Old Jan 29, 2004 | 03:03 PM
redboost10's Avatar
you could just go all the way back with 2.5"
is the extra 2.25 from ic piping?
Old Jan 29, 2004 | 03:12 PM
5STAR3's Avatar
yea it is extra from the ic piping.
i dont really want to go 2.5" all the way back cause that would cost me too much right now. thats what i plan on doing this summer when i can work(i go to school right now)
Old Jan 29, 2004 | 03:16 PM
redboost10's Avatar
well im not sure how you can put 2.25 right off that flange of the turbo outlet. maybe someone else will reply soon with a good idea man, good luck
Old Jan 29, 2004 | 03:30 PM
5STAR3's Avatar
i want something like this, only that does the opposite.
this one goes from small to bigger, but all would have to do is flip that piece around, anyone know where i can get that piece?
Old Jan 29, 2004 | 03:32 PM
redboost10's Avatar
that guy made that piece, not sure how though
BlackT5
Jan 11, 2007 06:27 PM
sylvain
Aug 13, 2004 03:39 AM
VTECR021
May 11, 2004 03:01 AM
crx1856
Jun 25, 2003 01:41 AM
