Questions on Boost Creep
Old Oct 21, 2005 | 11:03 AM
376R's Avatar
Default Questions on Boost Creep
Im about finished getting my parts i wanted to upgrade and ready to install. My tuner saw my manifold and asked me what wastegate i was planning on using. I said my 38mm tial. I was told to get atleast a 44mm or i can pretty much expect boost creep. Im not sure if its b/c itll be making a decent amount of power or what, but any helpful input you guys could give id appreciate thanks.
so, my question is.. should i expect boost creep with my 38mm.. what should i do..
power goals ...eh.. about 385whp on pump
My setup.
B18c (head was port/polish w/a 3 angle)
srp 9.2-1 pistons
eagle H beam rods
JE rings
skunk 2 manifold
custom made by "me" manifold
custom 3" downpipe with electronic e cutout
brand new sc34
hks ssq
spearco front mount
etc..
Old Oct 21, 2005 | 12:44 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Questions on Boost Creep (klubhed1)
you have pics of the manifold? if it is like the drag and only pulling exh off of 1 runner, with a 3" d.p. you may have creep issues especially with a cutout.
Old Oct 21, 2005 | 01:44 PM
376R's Avatar
Default Re: Questions on Boost Creep (boostedcivicsir)
Old Oct 21, 2005 | 01:49 PM
Mr. Badwrench
if you are trying to stay with low boost, you may have creep. you may be ok, but id like to see other oppinions, i have a 44 on mine but i plan on low boost except on race gas.
Old Oct 21, 2005 | 02:07 PM
376R's Avatar
well i plan on having 2 settings a lower boost for daily driving, then when i wana play around, ill throw in some race fuel, select the high boost on the boost controller, and open up the cutout.
btw il be using Neptune
Old Oct 21, 2005 | 02:48 PM
Jared's Avatar
With a T3 hot side I've never seen a "ram horn" style manifold properly control boost with just a 38mm gate.
Old Oct 21, 2005 | 02:58 PM
376R's Avatar
Default Re: (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">With a T3 hot side I've never seen a "ram horn" style manifold properly control boost with just a 38mm gate.</TD></TR></TABLE>what size does then...
Old Oct 21, 2005 | 04:37 PM
yee SERIOUS's Avatar
how much boost? u might be more satsified with the 44mm
Old Oct 21, 2005 | 06:07 PM
376R's Avatar
Default Re: (undercoverdc2)
probably low boost at 12 and high boost around 18
Old Oct 21, 2005 | 06:10 PM
Adi Radoncic's Avatar
On Fire!
With your turbo and that manifold a 44mm wg couldn't help ya..
Old Oct 21, 2005 | 07:56 PM
376R's Avatar
Default Re: Questions on Boost Creep (Adi Radoncic)
wahts wrong with it.. what do i need
Old Oct 21, 2005 | 08:10 PM
On Fire!
Run a couple of 38's
Old Oct 21, 2005 | 08:13 PM
376R's Avatar
running 2 38's would be better? how can i do that with this mani
Old Oct 21, 2005 | 09:00 PM
On Fire!
One on each runner on the front angeling them at 45deg.
376R's Avatar
im not making anotehr manifold, and i already cut the hole in this one... so what can i get that will work ?
Old Oct 21, 2005 | 09:03 PM
On Fire!
It can still be done man, just make the hole bigger length vise than merge 2 tubes together and weld them to the manifold.
What spring are you running in the wastegate now?
Old Oct 21, 2005 | 09:08 PM
vaporboy12's Avatar
my full race mani and 44mm wastegate held boost fine at 10psi no creep at all
Old Oct 21, 2005 | 10:15 PM
On Fire!
Default Re: Questions on Boost Creep (vaporboy12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaporboy12 &raquo;</TD></TR><TR><TD CLASS="quote">my full race mani and 44mm wastegate held boost fine at 10psi no creep at all
What pressure spring are you running?
I have heared of some people having luck running the 7psi spring and controlling the rest with a controller, to get rid or the spike or creep.
I'm just thinking that 2 38's will solve the problem for sure but a single 44mm might do it too.
Modified by Adi Radoncic at 1:33 AM 10/22/2005
007EG
Nov 15, 2007 03:55 AM
1JDMDOMINICAN
Jan 20, 2005 09:32 AM
jonnybravo
May 26, 2004 08:38 AM
RedStarGsr
Oct 14, 2003 10:56 PM
