Questions about Hondata 2B
Old Feb 22, 2003 | 01:22 PM
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
Default Questions about Hondata 2B
Can I simply just plug and play everything and I'm set to go?
I don't seem to be able to adjust my own fuel/air settings? Am I not allowed to with this version with the Hondata? I'm not too sure on what I can, and cannot do with this.
I want to install it first, then install my turbo later, lookign through the rom editor doesn't seem to allow me to tune it myself.
Do Hondata have base maps that I can use to simply install, and run for th etime being before I take it to be fully tuned?
Old Feb 22, 2003 | 01:50 PM
ekb18c's Avatar
Default Re: Questions about Hondata 2B (Snafu-Si)
2b's wont let you tune yourself. You will have to have someone with a 4b tune it for you. You can get a base map off hondata's site that matchs your setup. However, inorder for you to burn the eeprom you will need the pocket programmer.
I wouldn't suggest you install the 2b first.
Old Feb 22, 2003 | 07:37 PM
Snafu-Si's Avatar
Default Re: Questions about Hondata 2B (ekb18c)
Please let me know what is the best course of action that you would recommend?
Old Feb 24, 2003 | 02:14 AM
Snafu-Si's Avatar
bump
Old Feb 24, 2003 | 06:31 AM
b16ahybrid's Avatar
You could always get it, install it and have hondata retailer tune it for you...............
Old Feb 24, 2003 | 08:44 AM
TurboTegB18c's Avatar
whichever dealer you buy the hondata from should be able to program a stock base map for you. Paul
Old Feb 24, 2003 | 12:12 PM
Snafu-Si's Avatar
Default Re: Questions about Hondata 2B (TurboD16Z6)
I was just basically wondering if I can get it put in for the immediate time being, and if there was a base map in the system itself so I could acctually drive it over to a place to get it tuned.
But I don't know that.. if I get it installed, if there is ANY kind of map in it at all. I mean,, if I install it, and my car doesn't start... well, that would suckass. I don't know if it will give me spark or anything basically. I guess the best way is to all the place where I got it from.
Old Feb 24, 2003 | 12:57 PM
Just ask the place you got it from what kind of base map is in it.
Old Feb 24, 2003 | 01:15 PM
DeepSi's Avatar
if you have a basemap that is close to your setup, you should be able to drive around till you get to your tuner.
greddy2244
Engine Management and Tuning
May 6, 2012 09:01 AM
Rain_man
Aug 5, 2004 10:00 AM
JrCRXHF
Apr 6, 2004 11:30 AM
Scott - 93HB Si
Feb 28, 2004 05:22 AM
