Questions about Golden Eagle block
Old Apr 24, 2003 | 09:35 PM
milf H U N T E R's Avatar
Default Questions about Golden Eagle block
Do all Golden Eagle sleeved blocks come with this support around the sleeve? http://overboost.com/pix.asp?i...2.jpg
I found a Golden Eagle sleeved LS for sale but it doens't have this support. Is it safe to run 20+ lbs. on this type of open deck sleeve? All the GE sleeved blocks I have seen come with this support. Also, the block is not o-ringed, do you think a good local machine shop would be able to o-ring it? Thanks.
Old Apr 24, 2003 | 10:11 PM
@irborne's Avatar
Default Re: Questions about Golden Eagle block (RAwDeeLuX)
if it's GE, then it should have the brace, check with them and see!
Old Apr 24, 2003 | 11:00 PM
kamira's Avatar
Default Re: Questions about Golden Eagle block (@irborne)
i think ge now offers two types of resleeves one type of a econco sleeve and then there normal gorrilla sleeves, the gorrilla ones are the ones with the brace in the water jackets. Thats the one you want. The other one is not worth it IMO
Old Apr 24, 2003 | 11:16 PM
MikeMAN's Avatar
those may look funny because those are a new design i believe.
mike
Old Apr 25, 2003 | 07:48 AM
Default Re: Questions about Golden Eagle block (MikeMAN)
bump
Old Apr 25, 2003 | 08:20 AM
Howitt's Avatar
your block wasnt o-ringed
Old Apr 25, 2003 | 08:27 AM
bryan305's Avatar
Default Re: Questions about Golden Eagle block (Howitt)
all sleeved blocks have some sort of support around the sleeve...that's the whole point of having it done. GE uses those tabs, darton and aebs fill up the whole area around the sleeve, save for the coolant passages.
Old Apr 25, 2003 | 08:38 AM
b18bturbo's Avatar
Default Re: Questions about Golden Eagle block (bryan305)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bryan305 &raquo;</TD></TR><TR><TD CLASS="quote">all sleeved blocks have some sort of support around the sleeve...that's the whole point of having it done. GE uses those tabs, darton and aebs fill up the whole area around the sleeve, save for the coolant passages. </TD></TR></TABLE>
Not all sleeved block have supoprt on the upper portion of the sleeve.
GE has 2 versions of blocks godizlla with sleeve support and std without
Darton has 3 levels of sleeved closed deck open deck with tab support, open deck without.
Old Apr 25, 2003 | 09:04 AM
bryan305's Avatar
Default Re: Questions about Golden Eagle block (b18bturbo)
Please link pics of what you're talking about. The only ones I have seen have had supports other than just at the base of the sleeve.
Old Apr 25, 2003 | 09:22 AM
rOby's Avatar
your wrong bud,
there are 3 stages to darton sleeves. open deck, another version of the open deck, and lastly the closed deck one (which is basically a block guard and sleeves).
it does not go all the way down the jacket.
ge has two stages now too, one econo sleeve w./ no support tangs and the original sleeves which do have the tangs. the non tanged one is 100bux cheaper.
rs machine uses an open deck on all their sleeves but im pretty sure if u ask nicely you can get them to put a block guard on too.
Old Apr 25, 2003 | 09:36 AM
bryan305's Avatar
Default Re: Questions about Golden Eagle block (rOby)
ok if I'm wrong, no prob. I just would like to see pics, since I've never seen this before.
Old Apr 25, 2003 | 10:57 AM
intekragsr's Avatar
Heres my open deck Darton Sleeves 83mm bore
Old Apr 25, 2003 | 12:49 PM
alpha's Avatar
Here are my Godzilla sleeves.
http://photos.yahoo.com/bc/alp...o.com/
Old Apr 25, 2003 | 01:29 PM
bryan305's Avatar
Default Re: Questions about Golden Eagle block (intekragsr)
Do those darton sleeves have bracing half way up?
I thought all the GE sleeves looked like those godzilla sleeves...
I guess on me
Old Apr 25, 2003 | 01:32 PM
intekragsr's Avatar
nope no bracing on the dartons. I dont really need more bracing. Im only looking to run 15 pounds max.
Old Apr 25, 2003 | 02:12 PM
tegasaurus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bryan305 &raquo;</TD></TR><TR><TD CLASS="quote">Do those darton sleeves have bracing half way up?
I guess on me</TD></TR></TABLE>
GE makes the godzilla sleeve, right?
alpha's Avatar
Default Re: Questions about Golden Eagle block (tegasaurus)
Correct.
4.8t
Sep 7, 2011 06:05 AM
h22_crx
Apr 6, 2006 12:29 PM
miller
Dec 16, 2003 02:30 PM
Civicdrgrcr
Nov 19, 2002 03:00 AM
InfamousRS
May 10, 2002 08:12 PM
