question on compression ratio?
Old Oct 5, 2003 | 02:27 PM
reditr's Avatar
Default question on compression ratio?
Dear guys i lowered my itr 's compression from 11.1 too 9.1 would i have to tune the distributors timing again, or it won t affect it at all by just changing the compression ratio? i am asking this question because in this day i had some problems . i had some leakage from a cam seal and took the cams out and replace it , but now i have these other problem, the car was very powerful before i took the cams out as soon as i rebuild my cams back and everything on the car seems very retard it up as it is without power and at 4000-5000 rpm the car will like lose all it s power. The only thing that i did is i advanced in full from the distributor and the car nearly back to normal again. As i have checked again the cam and crank timing which seem d to be good too. Any help guys?
Old Oct 5, 2003 | 02:42 PM
danl's Avatar
Banned
Default Re: question on compression ratio? (reditr)
If you set your cam and ignition timing exactly as it was then you should have the same power. I would double check the settings.
Old Oct 5, 2003 | 02:50 PM
The Destroyer's Avatar
Default Re: question on compression ratio? (danl)
Set it back to stock, and if it was never touched dont worry about it until you have to tune again.
Rushintegra
Apr 28, 2013 08:37 PM
SOHC SPEED
Jul 18, 2008 11:05 PM
jeffsciv23
Mar 26, 2007 02:08 AM
allmtrdc4
Feb 12, 2006 09:00 PM
Convoy
Jan 14, 2004 12:18 PM
