Question about wastegate size
Old Sep 16, 2009 | 07:17 PM
Hybrid96EK's Avatar
Default Question about wastegate size
I bought a manifold, supposed to be a rev hard B series A/C compatible manifold. Anyways, the hole for the wastegate measures 36.75mm. Does this mean I need a 36mm wastegate? Can you mount a 38mm wastegate without problems? Should I port the opening to 38mm?
Old Sep 16, 2009 | 07:23 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Question about wastegate size
Think about it... it is only .059" (roughly a 1/16th of an inch) off of 38mm... That opening will work with a 35mm or a 38mm waste gate... take your pick. The port is fine as is...
Old Sep 16, 2009 | 07:30 PM
Hybrid96EK's Avatar
I thought more about it after I posted. The slight difference should have 0 effects. The wastegate opens by moving the piston up, which wouldn't matter how large the port is in terms of interfearance between the manifold/wastegate. Got it. Thanks.
Old Sep 17, 2009 | 03:01 AM
DO IT ON ALL FOURS
Exactly.
cleansi
Aug 27, 2010 08:58 AM
k9n
Feb 3, 2009 05:09 PM
1RMDave
Nov 16, 2004 02:17 PM
VTC_CiViC
Jul 21, 2003 01:16 PM
NyQuiL
Jul 15, 2003 11:14 PM
