Question about the stock Fan
Old Mar 25, 2003 | 12:38 PM
RyanAutry's Avatar
Default Question about the stock Fan
I am looking to replace my stock '92 Civic Si Fan with a Push style to give me a little more room in my engine bay.
At pep-boys they have a few push fans for $50 or so and flow 600cfm.
Does the stock fan flow more then 600cfm? I don't want to down grade.
Old Mar 25, 2003 | 01:10 PM
scttydb411's Avatar
Default Re: Question about the stock Fan (RyanAutry)
i'm assuming that you are going to mount it in front of the rad/condensor? why not just use the stock and reverse the wiring...or will you have fitment issues with your intercooler? i'm going to need to do this for my ac condensor fan.
Old Mar 25, 2003 | 01:34 PM
RyanAutry's Avatar
I found this one on Summit.
It's a Flex a Lite Pusher Fan.
1250 CFM
2.25" deep
$97.00
This will be going in between my Intercooler and Radiator.
Old Mar 25, 2003 | 02:49 PM
RyanAutry's Avatar
What do you guys think of that fan?
Old Mar 25, 2003 | 04:38 PM
Peter K's Avatar
New User
I have that one but a puller and i must say that it is really strong.. you can feel it when it turns on
Old Mar 25, 2003 | 04:39 PM
RyanAutry's Avatar
Default Re: Question about the stock Fan (Peter K)
That's good to hear.
Old Mar 25, 2003 | 05:19 PM
Jason kiDD's Avatar
Ones from autozone are just as good. I have one and I believe it personally outflows the stock one.. I have a civic though.
Old Mar 25, 2003 | 05:24 PM
philo's Avatar
You dont want to use a fan with a cowl as a pusher fan, you want to use a generic autozone, oreilys, pepboys unit. They are 850cfm and are effective pusher fans as they dont have a cowl to block airflow at cruising speed.
Old Mar 25, 2003 | 05:47 PM
integra_gsr98's Avatar
Default Re: Question about the stock Fan (philo)
I use generic Imperial fans from Checker and they work great. I think my cost on them thru our shop account was like 55 dollars. Flow plenty and easy enough to install.
Old Mar 25, 2003 | 10:28 PM
RyanAutry's Avatar
Thanks Guys.
Old Mar 26, 2003 | 05:23 AM
BROOD's Avatar
Summit FLX-140
Old Mar 26, 2003 | 07:35 AM
TurboDC4's Avatar
Default Re: Question about the stock Fan (SLPR)
What does the stock fan flow?
Old Mar 26, 2003 | 08:01 AM
PM-Performance's Avatar
i got imperials, they work great , strong as hell , at least they sound it
Old Mar 26, 2003 | 10:04 AM
RyanAutry's Avatar
Default Re: Question about the stock Fan (TurboDC4)
I dunno?
Old Mar 26, 2003 | 10:10 AM
pub's Avatar
pub
how do those fans attach? Looks like magnets.
Old Mar 26, 2003 | 10:12 AM
Tinker219's Avatar
I dunno?
I dont know either, but cant you just use the stock fan, put in on the front of the radiator, and switch the wires? the only reason why you wouldnt be able to would be because of the blade design, but I dont why why it wouldnt work either way....
Old Mar 26, 2003 | 10:36 AM
RyanAutry's Avatar
Default Re: Question about the stock Fan (Tinker219)
I dunno?
I was thinking of that. But I did a little measuring. I don't have the room.
Old Mar 26, 2003 | 10:43 AM
Tinker219's Avatar
room helps I dont have any factory metal left, all tube, so I have lots of room
Old Mar 26, 2003 | 10:47 AM
*Boostwerks*'s Avatar
Perma cool 1650!...
A 12" fan that is nearly SILENT....yet flows 1650 CFM!
Full ballbearing construction, and is only $85 from Summit...
EDIT: oh yes, and it is push/pull style.
[Modified by Bryson, 12:48 PM 3/26/2003]
[Modified by Bryson, 12:52 PM 3/26/2003]
Old Mar 26, 2003 | 03:28 PM
ITRTurbo's Avatar
Default Re: Question about the stock Fan (Bryson)
hmm what is the part number for this Ball bearing fan?
what size it that?
[Modified by ITRTurbo, 7:42 PM 3/26/2003]
Old Mar 26, 2003 | 03:34 PM
RyanAutry's Avatar
Default Re: Question about the stock Fan (ITRTurbo)
PRM-19008
Old Mar 26, 2003 | 05:20 PM
flat-blk-HB's Avatar
so do the push fans help out on cooling, or is it just for room?
Old Mar 26, 2003 | 05:26 PM
RyanAutry's Avatar
Default Re: Question about the stock Fan (flat-blk-HB)
Just for room.
Old Mar 26, 2003 | 05:46 PM
Smashback's Avatar
and for cooling...i'm sure stock fans are between 600-800 RPMs which is good for upto like 175 hp engines..any of these fans you get are at least 1200...i think my SPAL is like 1500 or something and it's the thinnest fan i've found, smaller than anything at summit
Old Mar 26, 2003 | 06:16 PM
Just for room.
but it seems as if there is a IC in front of your radaitor then a push fan would be more likey to get more air and send in though the radaitor then a pull could get since something is blocking it. Maybe I am just rambling.
