question about sc44
Old Jun 5, 2006 | 10:10 AM
TURBODC4TEG's Avatar
Default question about sc44
i recently got a sc44 in december, its still brand new just sitting in the bag. i am almost done with my build and gonna put it on. do u think the turbo is ok or should i have put oil in it every once in awhile and spin it to keep it lubed up. thanks
Old Jun 5, 2006 | 10:58 PM
Default Re: question about sc44 (TURBODC4TEG)
i know someone knows
Old Jun 6, 2006 | 05:25 AM
notoriousB's Avatar
if the bag is still sealed I'd just leave it alone until you're ready to use it, it should be fine.
Old Jun 6, 2006 | 07:05 AM
Default Re: question about sc44 (notoriousB)
reason i'm wondering is that if the bearings aren't lubed good it will blow
Old Jun 6, 2006 | 07:12 AM
b18bturbo's Avatar
just make sure you prelube it whne you hook it up after that you are golden no issues to worry about .
Old Jun 6, 2006 | 11:50 AM
Default Re: question about sc44 (b18bturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo &raquo;</TD></TR><TR><TD CLASS="quote">just make sure you prelube it whne you hook it up after that you are golden no issues to worry about .</TD></TR></TABLE>
what u mean prelube, like prime it before i start up, i knew that. but should i do anything else?
Old Jun 6, 2006 | 11:58 AM
rudebwoy's Avatar
just like you do a freshly built engine. you remove the ecu fuse, and crank the motor until you see oil pressure on the gauge.
anyways you have nothing to worry about, brand new turbos don't spin at idle, my sc61 did not spun at idle until after 500 miles
Old Jun 6, 2006 | 11:53 PM
Default Re: (rudebwoy)
oh i was mainly wondering since i haven't opened it if i didn't put like a few drops of oil in the center section to keep the seals lubed that i might blow if i didn't since its brand new and hasnt been opened since december
94eh2
Feb 16, 2007 11:49 AM
xDicktonesx
Feb 14, 2006 07:29 AM
SolKist
Nov 30, 2005 10:47 AM
00supercivic
Dec 22, 2004 07:28 PM
jfoster
Sep 6, 2004 09:48 AM
