Question about running untuned.
Old Feb 15, 2006 | 11:58 AM
O16581724 5 2 5's Avatar
Default Question about running untuned.
Until i can find someone that really knows what they're doing, i'll be running my car untuned. I have a wideband, so i can mess around with it until my numbers are below 12, my question is: Is it safe to run untuned as long as my numbers are under 12?
Old Feb 15, 2006 | 12:00 PM
sohc_turd's Avatar
Default Re: Question about running untuned. (O16581724 5 2 5)
well since you have a wideband and it sounds like you have a way to control fuel and ignition, just tinker around till you figure it out.
Old Feb 15, 2006 | 12:12 PM
Zakar's Avatar
dont run much boost.. dont beat on the car.. (unless you want to rebuild)
your Air Fuel ratio isnt the only variable.. if it was.. tuners would be out of buizness
no matter how much we say it.. people dont listen.. you need to get it tuned professionally..
Old Feb 15, 2006 | 12:45 PM
Default Re: (Zakar)
I'm running conservative ignition timing, just asking if as long as i keep my fuel under 12 if it's safe as far as fuel, like fluctuating from 10s to high 11s.
Old Feb 15, 2006 | 12:57 PM
Schister66's Avatar
Man U FTW
you spent a lot of money to get your car to the point its at right now so why risk blowing it up? I would maybe run untuned for a little while, but i wouldn't beat on the car whatsoever!
----Get tuned ASAP---------
Old Feb 15, 2006 | 01:08 PM
HennessySoldier's Avatar
Default Re: (Schister66)
sounds like you dont know much about tuning.... dont risk it
Old Feb 15, 2006 | 01:14 PM
Default Re: (soflab18cturbo)
I pretty much said in the first line i don't know what i'm doing with tuning, haha.
Old Feb 15, 2006 | 01:46 PM
Zakar's Avatar
keep in mind too low of a AFR can also cause damage
Old Feb 15, 2006 | 02:34 PM
Si Shane's Avatar
Default Re: (Zakar)
TaKe it easy and do it yourself. With some conservative timing maps, two hours googling about spark plugs and how to read them, a magnifying glass and a timing gun you should be able to churn out a map that you can use for a long time.
Professionals are for people who dont have a lot of time and max power
Old Feb 15, 2006 | 06:21 PM
Default Re: (Si Shane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si Shane &raquo;</TD></TR><TR><TD CLASS="quote">TaKe it easy and do it yourself. With some conservative timing maps, two hours googling about spark plugs and how to read them, a magnifying glass and a timing gun you should be able to churn out a map that you can use for a long time.
Professionals are for people who dont have a lot of time and max power </TD></TR></TABLE>
Exactly, i'm not worried about max power yet, i'm just needing guide lines so i don't blow my motor. Don't want that redneck beside me revving his glasspacked truck to think i'm intimidated by it.
It's hard to find someone that can tune Uberdata here, i've found one person that could do it and he was a real ******* so expletive him getting my money.
Old Feb 15, 2006 | 06:33 PM
coneheadsracing's Avatar
Default Re: (O16581724 5 2 5)
you don't need to get it proffessional tuned, unless you want to. I ran with only a wide band, and never hooked up a laptop for 5000 miles. I ran for a while at 10 psi, and then upped it to 15 later on. I now have a laptop and will use that for next spring, but to say you WILL be rebuilding it.... I still had great compression before i pulled mine this winter. Just listen, feel, and watch. Good luck.
Old Feb 15, 2006 | 06:52 PM
evilone's Avatar
Default Re: (coneheadsracing)
It only takes a second or two to blow a motor, try to find someone with some experience
Old Feb 15, 2006 | 06:58 PM
XX Boosted Si XX's Avatar
Default Re: (prostock)
Get Hondata and give the guys at King Motorsports a call!! My car runs like a champ!!
Old Feb 15, 2006 | 07:11 PM
SOHC_MShue's Avatar
Si Shane has the right idea . Run conservative timing to start off, keep your afrs in check, and keep a constant eye on the plugs for any detonation.
Old Feb 15, 2006 | 07:36 PM
Default Re: (SOHC_MShue)
Good news! Si Shane and i were talking on IMs and he suggested i check out Crome, when Google searching it and reading on it, i found a directory of tuners for Crome, in this directory, i found someone that can tune Uberdata or Crome about 200 miles from me, so i'm good to go.
Old Feb 15, 2006 | 07:53 PM
evilone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by O16581724 5 2 5 &raquo;</TD></TR><TR><TD CLASS="quote">Good news! Si Shane and i were talking on IMs and he suggested i check out Crome, when Google searching it and reading on it, i found a directory of tuners for Crome, in this directory, i found someone that can tune Uberdata or Crome about 200 miles from me, so i'm good to go. </TD></TR></TABLE>
good deal, tuning is everything!!
Old Feb 16, 2006 | 09:07 AM
JDM turbo DC's Avatar
476 whp / 323 tq @ 17 PSI
whats the website for that directory? ive heard of one place here in san diego but prefer tuners with more feedback like churchs, churchs does crome right? (west coast)
Old Feb 16, 2006 | 10:42 AM
Default Re: (JDM turbo DC)
Here's the Uberdata and Crome directories.
http://forum.pgmfi.org/viewtop...77ed6
-Crome
http://uberdata.pgmfi.org/foru...=2832
-Uberdata
I lost the main site, it also had a directory link for i think Hondata.
hatchyboy89
Sep 11, 2006 10:00 AM
spockeg
Sep 1, 2006 04:26 PM
vmm
Jul 5, 2004 10:55 PM
SpoonFedHatch
Feb 24, 2004 05:59 PM
Elite Hatch
Sep 25, 2002 10:10 AM
