Question about mixing oils
Old Feb 6, 2004 | 03:25 PM
vtec.dc2's Avatar
Default Question about mixing oils
Our oils are milti-viscosity.. So if i'm to take sae20W and mix it with sae40.. would that make it sae20w40? or is it just not that simple. And if it possible to make it work, how much of each should i add?
Old Feb 6, 2004 | 08:07 PM
hybridsol's Avatar
Default Re: Question about mixing oils (vtec.dc2)
This is a joke right?
Old Feb 6, 2004 | 08:30 PM
vtec.dc2's Avatar
Default Re: Question about mixing oils (hybridsol)
not at all.. i take it you're the expert when it comes to gasoline oils - i'm not.. care to explain why this idea wouldn't work?
Old Feb 7, 2004 | 12:46 AM
hpfsi's Avatar
If I'm not mistaken oils are rated on viscosity and the temperature range within which a level of viscosity is maintained. What qualities are you looking for that can't be found with an off-the-shelf motor oil? What type of environment?
Old Feb 7, 2004 | 12:49 AM
lazerus's Avatar
Default Re: Question about mixing oils (hpfsi)
No.
Sae20W is a single viscosity.
Sae40w is a single viscosity.
Mixing them togeather will yeild a 20 and 40 weight combination, not a multi-viscosity oil.
Old Feb 7, 2004 | 11:05 AM
vtec.dc2's Avatar
Default Re: Question about mixing oils (lazerus)
oh.. i see.. thanks
Old Feb 7, 2004 | 11:31 AM
vtec.dc2's Avatar
alright.. after reading the right reference.. i understand how multi-viscosity oils work. for example: 20w base + polymers would increase it to 50 as the car warms up..
Old Feb 7, 2004 | 11:59 AM
Muckman's Avatar
Moderator in Chief
you average the two together and get 30w
Old Feb 7, 2004 | 12:09 PM
vtec.dc2's Avatar
Default Re: Question about mixing oils (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">you average the two together and get 30w </TD></TR></TABLE>
thats probably what it would end up doing.. now.. let me give this a better try..
if i'm to mix sae10w40 with sae30 will that increase it to say.. 20w40 (or just make it higher than 10w40)? - does that make sence. i understand that i would have ot send this out and have it tested.. but i don't want to do anything until it makes sence.
FRKWOO
18
Feb 1, 2009 09:56 PM
turboD_EG
Jul 29, 2007 11:58 AM
djtony5
Nov 14, 2005 04:59 PM
DC4KiD
May 22, 2005 07:31 PM
deeksmooth
May 26, 2004 07:10 AM
