question about intercooler pressure drop
Old Oct 22, 2002 | 06:11 AM
Mr. Softee's Avatar
Default question about intercooler pressure drop
why does pressure drop occur? Is it becuase of air's temperature drop leading to pressure drop in accordance with Amonton's laws? Or is it from something else? I would asume pressure drop is good, as it is impossible for air to become cooler without loss of pressure(asuming volume and incoming pressure are constant)- correct?
Old Oct 22, 2002 | 07:33 AM
94turboteg2's Avatar
New User
Default Re: question about intercooler pressure drop (94goldjungsr)
I read somewhere it was because of "aerodynamic drag".
The key is as long as the density charge gain is greater than the power loss (due to pressure drop) the intercooler is ok.
Old Oct 22, 2002 | 08:27 AM
bmm89's Avatar
Default Re: question about intercooler pressure drop (94turboteg2)
They had a real good series of articles on the autospeed site(crazy aussies) in which they measured the plumbing pressure drops and fixed them... http://autospeed.com/index.html
Old Oct 22, 2002 | 09:19 AM
mos's Avatar
mos
Default Re: question about intercooler pressure drop (bmm89)
direct link:
http://www.autospeed.com/A_0652/page1.html
err try this one.
http://www.autospeed.com/A_0754/page...rc=suggestions
[Modified by mos, 10:25 AM 10/22/2002]
Old Oct 25, 2002 | 08:25 AM
craesq's Avatar
The pressure drops because the temperature drops. Colder air is more dense (i.e. you can fit more atoms in the same space). I was running 7psi without an intercooler and it dropped to 5psi when I put the intercooler on.
Old Oct 25, 2002 | 10:50 AM
Prod's Avatar
Simple, pressure drop occurs due to airflow restriction
Airflow can be restricted by tight bends in pipes, inadequate pipe sizing, obstructions in air path etc...In an intercooler the main thing that is going to cause pressure drop is turbulator density. If you have very dense turbulators then the air will remain in the IC longer and you will likely see more efficiency, however at the expense of pressure drop. Vice versa as well...The other thing with IC's that can cause a nasty pressure drop is bad end tank design and of course leaks.
Old Oct 25, 2002 | 01:07 PM
niedejb's Avatar
Default Re: question about intercooler pressure drop (Prod)
If you had no pressure drop, you would get no residence time for the air in the IC.
You will always have a drop at the IC otherwise you'd get no cooling (since the air passes right through what is cooling it).
Old Oct 25, 2002 | 02:23 PM
FredoSP's Avatar
may we also add a friction coeffiecient effect to this, when the heat is transferred?
Calc physics was so long ago
Old Oct 25, 2002 | 04:24 PM
Quick 200k Mile Motor's Avatar
whats average for a bolt on turbo kit?
1.5psi drop?
Old Oct 25, 2002 | 04:53 PM
FredoSP's Avatar
Default Re: question about intercooler pressure drop (Quick 200k Mile Motor)
that sounds right to me!
Old Oct 26, 2002 | 08:30 AM
Default Re: question about intercooler pressure drop (FredoSP)
cool, i asked because a while back someone posted a PWR vs. Spearco IC comparison. If i could remember correctly, one had more pressure drop than the other because of core design.
RNPoo7
Mar 8, 2005 11:46 PM
JM Performance
Dec 23, 2002 07:25 PM
integranator
Nov 22, 2002 12:37 AM
DSF
Apr 22, 2002 03:39 AM
