Question about installing 450cc injectors....
Old Sep 30, 2002 | 08:44 PM
freeplay's Avatar
Default Question about installing 450cc injectors....
I got some DSM 450cc's along with a resistor box. The plugs do not fit right with the new injectors. Do I hardwire them right onto the new injectors? Do you solder or what? Thanks
Old Sep 30, 2002 | 08:45 PM
turbosol's Avatar
Default Re: Question about installing 450cc injectors.... (BoostInBoi)
You can use obd1 injector clips or RC wire clips
Old Sep 30, 2002 | 09:25 PM
PressurizedSi's Avatar
Default Re: Question about installing 450cc injectors.... (turbosol)
Which side of the lead does the resistor tie into again? I keep forgetting.
Old Oct 1, 2002 | 01:36 AM
filetofit
Guest
Posts: n/a
Default Re: Question about installing 450cc injectors.... (PressurizedSi)
Doesn't matter as long as it's in series with the injector, ground side or power side it's all good.
The plugs should fit with a little grinding.
[Modified by filetofit, 10:37 AM 10/1/2002]
Old Oct 1, 2002 | 05:31 AM
dwilson's Avatar
Default Re: Question about installing 450cc injectors.... (filetofit)
There is a little plastic piece inside of each injector that will not let it the wiring harness slide onto the injector. I used a dremel and touched up and now they fit like stock.
Old Oct 1, 2002 | 04:36 PM
Default Re: Question about installing 450cc injectors.... (dwilson)
I understand that the 310cc injectors clips included with the GReddy kit are OBD1 correct? So they will connect with the DSM injectors?
Summary:
1. they fit tight into the mani. some dremel the o-ring?
2. require resistors to work on honda/acura
3. require OBD 1 style injector clips.
did I miss anything?
092eg6
Dec 23, 2009 01:38 PM
fortynineR
Aug 30, 2007 03:08 PM
Panoply
Jul 19, 2005 01:37 PM
Panoply
Jul 18, 2005 09:36 AM
Sprockets
Dec 22, 2002 11:21 PM
