Question about going b16 turbo?
Old Oct 2, 2006 | 09:32 PM
wfocrx's Avatar
Default Question about going b16 turbo?
I have been toying with the idea of going to the dark side (b-series) and was wondering if the it will be worth the hassle. My questions are...
about when would a stock b16 spool(~10psi) using a minilog+2.5" open downpipe on a .63a/r t3/t04e 50trim? my d16z6 doesn't get 10psi till probably right ~5k
how much power (with a good tune) would a healthy stock b16 on ~10psi with the before mentioned setup?
right now at ~9psi I'am trapping about 104-105mph in my 2075lb crx. would it be safe to say I will trap at least 110mph with a b16 at ~10psi?
Old Oct 2, 2006 | 10:07 PM
AaronJ's Avatar
Default Re: Question about going b16 turbo? (wfocrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wfocrx &raquo;</TD></TR><TR><TD CLASS="quote">I have been toying with the idea of going to the dark side (b-series) and was wondering if the it will be worth the hassle. My questions are...
right now at ~9psi I'am trapping about 104-105mph in my 2075lb crx. would it be safe to say I will trap at least 110mph with a b16 at ~10psi?</TD></TR></TABLE>
It would definately be worth it. You would probably spool at close to 5K, but that is plenty early.
You would probably put down anywhere from 240-300hp depending on alot of things. With that amount of power you would trap anywere between 110-118 or so. With a good launch you could get a high 11 second pass easy.
Old Oct 3, 2006 | 07:21 AM
wfocrx's Avatar
can a stock b16 take 10psi reliably if tuned, well?
Old Oct 3, 2006 | 07:55 AM
urbansi's Avatar
Default Re: (wfocrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wfocrx &raquo;</TD></TR><TR><TD CLASS="quote">can a stock b16 take 10psi reliably if tuned, well?</TD></TR></TABLE>
Depends who tunes it, and if the motor is healthy.
Old Oct 3, 2006 | 12:09 PM
AaronJ's Avatar
Psi doesn't really matter. I would just keep it under 300hp. With a good tune 300 should be fine.
1sikhatch
Jan 19, 2012 03:44 PM
kte324
Mar 26, 2009 05:25 PM
joethejoeman
Feb 6, 2007 04:37 PM
red_hatchback
18
Dec 6, 2005 05:52 AM
markvqwerty
Dec 13, 2004 09:29 AM
